oil leak
Old Feb 23, 2005
fi dx's Avatar
fi dx is an unknown quantity at this point
oil leak
i have a massive oil leak at my oil pressure sending unit where i tapped for the oil feed to the turbo right above the filter...as my luck would have it...i tried to take it off and do it over again using teflon tape or any sort of sealer...well it still leaks...if anybody had or has a leak there....what did you guys use to fix it?
Old Feb 23, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
try honda bond, it's used on ex's for the oil pan so it might do the job
Old Feb 23, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Did you put a BSPT or an NPT fitting in the port?
If you put an NPT fitting in... there's your problem, get a BSPT one.
Old Feb 23, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Yep. You used an NPT fitting. It isn't NPT.
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
671civicLX
Jun 13, 2015 05:56 PM
davidpaustin
May 20, 2015 12:59 PM
