???I've got a couple engine questions???
Old Jan 23, 2022
Berteasterly202's Avatar
Berteasterly202 is an unknown quantity at this point
I've got an 05 civic vp 5sp manual the oem engine is a D17a1.
questions:
1) if I did an complete engine swap would I be able to mount a D16y7 engine to my D17a1 transmission I know I may have to fabricate a few new engine mounts but would the block mount to the trans
#2) if I did a complete engine overhaul rebuild and used my factory D17a1 engine what all would I need to replace engine is bad because I purchased the vehicle with a rod knocking we tried to make it home after the purchase and unfortunately significant lost and lack of power and it was best to tow it the rest of the way, I intended on swapping d-17 series engines but my parts car got stolen, so if I choose to do a rebuild I know the connecting rods and a rebuild kit would be necessary but while I have the engine tore down what else would be beneficial to replace
Old Jan 23, 2022
FRSam's Avatar
Click Here
Re: ???I've got a couple engine questions???
1) Depending on how emissions and inspections go in Ohio, the D16 is not legally allowed in a newer car. Either way, it'd be way too expensive to make work.
2) I'm not sure I understand this question. You wanted to swap engines but you can't now? That's still probably the best course of action but I want to understand what you mean first.
Old Jan 23, 2022
Initially I had a 01 Civic Ex VTEC that was my parts car I was going to convert everything over to my 05 Civic VP but unfortunately I drove my 01 one last time and ended up getting it impounded at which time I did a little over a month in jail when I got out my ex had retrieved the car and stolen it now I have an 05 Civic VP with a blown engine and I'm debating rebuilding what I have or my boss gave me a 2000 model Civic for parts if the d16y 7 will bolt up to the transmission I have then the rest is golden motor mounts are simple Fabrications I just don't want to pull the engine and try to put it in unless I know it will mount
Old Jan 23, 2022
FRSam's Avatar
Click Here
It'll bolt up to the trans, but nothing else will work. You'll need a new wiring harness, ECU, custom mounts obviously, etc. It's more hassle than it's worth imo
What's stopping you from just using the 2000?
Old Jan 23, 2022
The 2000 it is not in the best condition it's also an automatic and there's an issue with the title it's a complete car though so I would have the wiring harness and the ECU and I'm pretty good with a welder the mounts are no issue
Old Jan 23, 2022
And I know it's not recommended due to the legality of it but I don't plan on letting a cop pop my hood to know that my engine is from an older car
Old Jan 23, 2022
FRSam's Avatar
Click Here
So Ohio doesn't have emissions testing?
Old Jan 23, 2022
No not anymore
Old Jan 23, 2022
FRSam's Avatar
Click Here
No not anymore
Cops wouldn't know the difference anyway, but emissions testing would sniff that out pretty quickly.
Yeah, have at it. Hopefully it works out.
Here’s a thread from another forum I’m on. It should help you out.
https://www.d-series.org/threads/d16y-8-engine-d17-a1-transmission.315515/#post-5174740
Old Jan 24, 2022
BrotatoChip's Avatar
Super Moderator
I have pulled a few D17s from the LKQ in Dayton. With a rod knock, I would replace the block with a good one from the junkyard, take the head to a machine shop for cleaning and flattening, new head gasket and timing belt kit. All in for like $500 if you're doing the work yourself.
MindBomber
Engine Swaps
Mar 12, 2021 10:12 AM
MindBomber
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Oct 16, 2015 08:40 AM
MindBomber
Newby
Sep 13, 2011 01:04 AM
lostid
Feb 20, 2005 09:38 PM
