A confusing one
Old Jul 23, 2022
jrenuard's Avatar
jrenuard is an unknown quantity at this point
A confusing one
Hello
I am the owner of a 2001 Honda Civic EX, and i have quite the issue
Recently, i had to take my vehicle in to get two sensors replaced- camshaft and crankshaft sensors. After the repair, issues slowly got worse since day one of repair
Initially, i was losing oil. But at that time, it wasnt from my pan as i had done my oil chaoge and the leak was old oil
Under my car, my entire left side past the bolt on the oil pan was damp with oil
Also on the left, there is a weird sound whenever i release the gas. It only really happened on the earlier gears, 1-2, and didnt do it on higher gears. The sound itself can be compaired to sticking your finger in a plastic fan- we all did it as a kid, you dont forget that sound
Fast forward a few days, and i break down. Just before the breakdown, my car jerked like i hit the breaks over and over again
Then i lost speed and power. All of my parts were locked up- break and gas pedals, and the steering wheel. Both my oil and battery lights came on with no engine light
Im unable to start the vehicle, whenever i try, there is a wirring noise coming from my lef. It sounds like a belt starts to move but everything else does not
Please, if anyone knows what this is about, i would love to have any information
Thank you very much
Old Jul 23, 2022
Re: A confusing one
don't try to start! likely your timing belt broke!
valves crash with pistons on these cars!
Old Jul 23, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Re: A confusing one
Agreed. Suspicion on the job by the shop for installing the sensors properly. They sit super-close to the timing belt. One of those comes loose it will grind up the timing belt. A previous post had this happen if you search around.
Gotta open it up and look.
Old Jul 23, 2022
Re: A confusing one
and that finger in plastic? Could might been the belt parts hitting the plastic case.
Sudden engine halt sounds consistent with snapped timing belt and valves crashing into pistons
Old Jul 23, 2022
Colin42's Avatar
Re: A confusing one
Snapped timing belt, hopefully you didn't bend any valves, and hopefully the shop used oe sensors
Geldingmakr
Dec 27, 2019 11:43 AM
blacklud
General 7th Gen
Oct 18, 2019 07:43 AM
elzocalo
Feb 23, 2018 02:05 PM
kimfromcali
Jul 11, 2011 05:53 PM
himhimself
Jun 14, 2008 12:33 AM
