Major misfire or fuel problem
Old Jul 18, 2022
Logankelsey's Avatar
Logankelsey is an unknown quantity at this point
Hello, 2004 Honda Civic 1.7 Vtech misfires when accelerating but is fine once car gradually gains speed. touch the throttle it misfires over and over again. acts like it is running out of gas. jumps and jolts forward. take your foot off accelerator runs okay. starts at about 3000 rpm. stopped a traffic light, car died, turned over and over again. press throttle it started. slowly press throttle its okay, press throttle like you mean it, misfires and wants to stall. Unplugged each coil at idle cylinder 1 and 2 engine idle changed but 3 and 4 did not change idle when coil unplugged. installed coils from another Honda,... no change in cylinder 3 and 4's engine idle. not sure if this is fuel or spark issue??????
PLEASE HELP, PLEASE REPLY
thanks
Old Jul 19, 2022
BrotatoChip's Avatar
Super Moderator
Re: Major misfire or fuel problem
Is the check engine light on? What faults? You could do a fuel pressure test to rule that out.
Old Jul 20, 2022
No engine light. so far number 2 cylinder fault, changed coil, fault gone on code reader, now a cam shaft sensor code, gonna start by "cleaning" the sensor there is alot of oil around it, will keep you posted, could need a new sensor. thank you for the reply
BlueEM2
Idle Issues
70
Jun 20, 2023 08:34 PM
04hcex
Idle Issues
Jan 19, 2022 01:09 PM
Brian4200
Idle Issues
May 3, 2019 08:39 PM
j00fek
Jul 11, 2014 08:54 PM
frmg0014
Jun 3, 2012 12:04 AM
