Removing block heater to drain engine block coolant
Old Sep 12, 2021
southofhell's Avatar
southofhell is an unknown quantity at this point
Hi, I am working on a 2004 Civic EX (D17A2 engine). I am looking to drain the coolant inside of the engine block. Rather than finding an engine block drain plug near the oil filter, I found a block heater in its place. Just wondering if it is common practice to remove block heaters in order to drain coolant. Generally, should I leave it alone or should I remove it just as I would a drain plug, then re-install it?
Old Sep 13, 2021
Re: Removing block heater to drain engine block coolant
remove it to drain
olivedoe
Jan 7, 2019 05:07 PM
RangeRider
Aug 30, 2014 08:50 AM
crypticlineage
Engine DIY
Aug 10, 2014 08:43 AM
laack
Nov 27, 2010 03:58 PM
chickenbuster
Jan 19, 2007 10:54 AM
