Headers Glowing Red
Old Aug 15, 2021
Shrieking Geek's Avatar
Shrieking Geek is an unknown quantity at this point
Headers Glowing Red
Good Morning Everyone,
I have just recently finished putting in a new D17A1 into my 2005 Civic DX. The new engine is exactly the same as the last other than the fact that it's from a 2002. Well I got the car running but when the car is up to temperature, and it's dark out, the headers glow orange a little bit and I don't know if a little bit of glow is ok, or if I truly have something wrong.
I am getting a CEL and the scanner tells me I have the codes P2279 (Intake Air System Leak) and P0507 (Idle Air Control System Higher Than Expected). I double checked the intake manifold and can't find any disconnected hoses or any sort of thing that could be causing a vacuum leak so that is confusing me. It is my understanding that if there is a vacuum leak, extra air could be getting in, making it run lean, and then that could cause the headers to glow.
If anyone has had experience with this, knows some procedures I could perform to test the problem, it would be much appreciated.
Thank you
PS I dont suspect a clogged cat, it is brand new
Old Aug 15, 2021
Wankenstein's Avatar
Re: Headers Glowing Red
If you haven't already check valves clearances.
A clogged catalytic converter and/or exhaust can cause glowing headers. Retarded ignition timing. Wrong air/fuel ratio. Faulty injectors.
raidermaniac
Dec 19, 2013 12:31 PM
hatE
Engine Swaps
May 25, 2006 06:57 PM
Rcbrnr4now
Nov 8, 2005 05:24 PM
AEMcivic
Dec 5, 2001 04:02 PM
