PDA
View Full Version : Engine
Pages : 1 2 3 4 [5] 6
  1. Random
  2. Oozing oil/headgasket
  3. oiled coils replaced, now getting misfire when warm
  4. Egr question
  5. coolant connector hose in rear (water pump to thermostat) [solved]
  6. p0139 3 months after a new downstream O2 sensor
  7. Exhaust Pipe Broken
  8. Rough idle and 2 misfires after timing belt change
  9. Code 1457
  10. Broke my 2nd tensioner spring in 6 months
  11. Huge intermittent loss of power...
  12. Engine noise when under load
  13. P0135 cel
  14. Power steering adjustment screw bracket
  15. Shoul I be considering a head replacement?
  16. Injector question and timing belt question
  17. Engine unresponsive after 1 minute, falters for a minute, then fine.
  18. Rough Idle and Almost Stalls
  19. Car shuts off
  20. burning oil bad after head gasket
  21. CKP sensor wont go all the way?
  22. Jerking when accelerating and decelerating
  23. TDC is this how it looks like?
  24. Unclip the wire from Crank Position Sensor! is this bad? need help...
  25. 2005 Civic - Just cranks but no start
  26. 2004 EX --Unknown oil leak--what did I miss?
  27. Rebuild?
  28. Oil Pump O-Ring - short cut?
  29. Unkonwn Problem. Ticking noise , civic 2005 196k
  30. Any easy way to check TB tensioner torque?
  31. Timing Belt/Possible valve damage
  32. Civic Noise-What is the possible issue?
  33. 2005 Honda Civic Muffler vibration
  34. Optimal Outside Temperature for Changing Spark Plugs
  35. Head Gasket - reassembly - RTV and thread lock??
  36. Installed rear main seal too deep?
  37. dented rear main seal when installing...
  38. need help crank and no start
  39. Cold start
  40. Holy Carbon Poo Batman! Help Please...
  41. should I do my oil pan?
  42. radiator
  43. O4 civic hard start
  44. 05 EX P2646 problem
  45. Spark plug tube seals vs. ignition coil seals vs. lower tube seals
  46. Suggestion needed, Oil leaking:Replace valve cover gasket and thermostat housing
  47. Valve cover gasket + timing belt check
  48. oil found on the left side and bottom
  49. 2001 Civic SI Coupe - Starts but dies in seconds
  50. head gasket or cracked head ?
  51. Replacing Secondary O2 sensor for second time in 2 years
  52. Engine Skipping when Warm
  53. Vtec solenoid gasket. Do I need the O ring as well?
  54. Started Car With Engine Not Correctly Timed
  55. AC and power steering belt tension adjusting
  56. Exhaust Leak: Headers -> A Pipe
  57. Snipped sensor in place of engine block coolant drain
  58. Engine light is coming on and going off.
  59. D17A1 with vtec top cover?
  60. 2004 EX - Gas pedal got stuck a bit. What makes it come back up?
  61. 04 Honda Civic ex oil leak
  62. Power Loss 2003 LX
  63. Cracked 02 LX Cylinder Head Cover
  64. Gas mileage suddenly bad.
  65. Do not use advance auto blue oilpan gasket!!
  66. Check the lights, idiot...
  67. Need help identifying engine
  68. Check engine light - no activity to o2 sensor
  69. Honda Civic 2005 power problem
  70. 2001 Civic LX "limp mode"/knocking?
  71. timing belt broke 2003 civic lx
  72. 2001 Honda Civic EX 4 Door oil leaking problem
  73. 01 nightmare
  74. Having issues with misfiring
  75. oil pan gasket question
  76. Valve cover and Valve cover gasket
  77. 2004 Civic coupe automatic
  78. P1361 & p1362
  79. 2002 Honda Civic LX Smog Issue
  80. Loss of Fuel Economy - Unexpected Solution
  81. loosing power for a seconds
  82. oil pan gasket replace question
  83. ep3 02 type r heavy misfire/sputter 4krpm when warm
  84. P1129, High RPM, Poor acceleration and more. Check this first :)
  85. Issues after head job and timing belt
  86. After headgasket code troubles!
  87. 2005 civic p2227 code
  88. Coolant Leak at Top of Radiator
  89. 2001 Civic Losing Power
  90. Multiple TDC sensor failures
  91. Knock sensor plug?
  92. Raw fuel smell and cranks longer then normal sometimes. 170k. Thoughs? suggestions?
  93. 2002 Honda Civic Ex Manual Bucking and Bogging in all gears
  94. TSB pertaining to P1457 Error code
  95. Crank shaft position sensor
  96. Cam sensor toast after head gasket
  97. P1259 vtec really sucks
  98. 2003 dx p0141, p0420
  99. Egr code and coolant in port.
  100. Another MPG Question
  101. Engine issue after head gasket job
  102. Hose Part Number
  103. Code error 340
  104. 05 civic rear engine mount bolts
  105. Drivability issues
  106. 2005 Civic EX SE Window Issue
  107. Done everything I know
  108. 2002 civic ex cps fault code 1362
  109. 04 Civic EX with engine from an 01 getting P0134
  110. Marks on timing belt don't line up. Normal?
  111. What's this squeal?
  112. EGR problems 0401 code HELP PLEASE!
  113. 2003 Honda Civic Intermittent P1259
  114. 2001 Civic LX Burnt Valve
  115. Repairing Spark Plug Threads
  116. 2005 civic EX p2646/engine failure?
  117. 04 civic si misfire mystery
  118. Here is what your valves may look like if your burning oil
  119. engine problems
  120. How do I put together a 05 EX Oil Pan
  121. Black oil and missing oil
  122. 2002 Civic LX fuel issue
  123. 2004 Civic LX P1457
  124. Fans Blow to cool engine, but not when A/C is on.
  125. Any difference between Nippon and Fuji thermostats?
  126. previous owner used wrong crank bolt..
  127. Help with the torque specs on a 02 Honda Civic VTEC 1.7 I can't find all of them
  128. up stream O2 sensor.. am I losing my mind?
  129. How does one flush a heater core on a civic?
  130. Check Engine Light, Code "P1457"
  131. 2002 Civic LX 02 Sensors and Speed Sensor problems.
  132. 2004 Civic catalytic converter
  133. Check Engine Light On, Can't Pass Smog
  134. D17a2 rebuild
  135. Changed O2 sensor, car jerks while accelerating
  136. Water Passage housing
  137. 02 civic motor mounting bracket
  138. D17 Engine Block Diagram?
  139. Will gasket of D16 fit in D17A engine?
  140. 2003 Civic - Found where the fuel smell is coming from...Question?
  141. 2004 Civic Oil Loss
  142. 2002 Honda Civic Ex 1.7L cooling fans won't turn on unless fan switch jumped
  143. 2003 Honda Civic camshaft position sensor
  144. Sporadic Engine Idle/Bogging issues
  145. 2002 civic sputters and bogs down
  146. Where is the starter? (diagram please)
  147. Spark plug gap question
  148. Water Passage Bolt & Nut Torque Specs
  149. Exhaust rattle, but don't think it is heat shields-need help finding issue
  150. 2004 Honda Civic Stalling/Jerking
  151. 2002 Honda Civic- HORRIBLE Idle noise
  152. 01 civic si no compression cyl 3
  153. Changing a front motor mount on MT
  154. 01 Civic EX oil leak 150000 on VTEC 1.7
  155. 2005 honda civic cam torque procedure
  156. Oil pressure switch connection?
  157. rod bearing knock /rod bearing install??
  158. Loss of power in 1st gear after start up
  159. Lossing power when pushing the fuel pedal to the floor
  160. Help! I stripped TB tensioner thread - Solved!
  161. Emissions below threshold. Help
  162. Need Help. Valve cover coil screw broke!!!
  163. How to get bolt off from the engine?
  164. Headgasket confirmed... anything else should I do? - ezone lecture on oil rings insid
  165. am i screwed?
  166. Loud noise coming from engine
  167. Radiator replacement questions
  168. P0420 intermittent
  169. '01 Civic EX engine oil leak
  170. Civic Si comes to Grinding, screaching, crunching stop.
  171. Help!. CamShaft at TDC,Turned Crank 2 Revs, No belt!
  172. Having issues with a pesky adjusting wing nut when changing serpentine belts (w/pics)
  173. Need help to swap 3 stage VTEC solenoid wire to JDM single VTEC
  174. Camshaft Sprocket Removal
  175. d17a2 head bolts
  176. 01 EX, Bad Oil Leak, causes?
  177. Help help. 04 civic si
  178. Power loss in accelerating need help
  179. wont run right
  180. Intermittent P0420
  181. Drain Plug Stripped
  182. car jerks going faster than 45MPH
  183. Help with name of broken sensor
  184. 2005 Civic SI missing after 2 hrs driving
  185. O2 sensor or A/F sensor
  186. Misfire Cylinder #3
  187. 2003 Honda Civic LX Coupe- Unusual Vibrations when it "rains"
  188. 2002 Honda Civic Ex, Never Ending Misfire
  189. Car starts and stalls after washing engine
  190. 02 Civic Lx stalling out after camshaft sensor replacement
  191. Car is dragging
  192. oil leak from intake mainfold or bad head gasket?
  193. Motor mount
  194. Heater core replacement instructions
  195. Valve job instructions...
  196. 04 civic ex timing belt check?
  197. Location of temperature sender
  198. cmp(tdc) sensor life span
  199. p0128 coolant thermostat error code
  200. P0300? Check for vacuum leaks.
  201. Help: my check engine light will not come on at all.
  202. 2001 EX coupe goes into limp mode, p0132
  203. Another P0420 code.... Technical
  204. Valve Stem Seal Replacement
  205. Can't Seem To Remove Upper Timing Belt Cover
  206. New (used engine)
  207. Head gasket kit 06110-PLA-E01, what does it include
  208. p1361 on '02 EX - question for rookie DIY
  209. 2004 honda civic dx
  210. 2 types of PCV valve? see pic!!
  211. Crank seal?? Video
  212. Theoretical Catalytic Converter Work
  213. Best radiator/best place to buy replacement radiator?
  214. Leaking oil, what is this
  215. D17A PCV Valve replacement?
  216. 2001 Civic Knock Sensor Replacement Help!
  217. P1362 TDC sensor no signal- problem solved!
  218. Crankshaft Position Sensor
  219. pulling engine > tranny help 01 civic lx
  220. 2003 Civic 1.7 fuel pressure
  221. Leak from VTEC solenoid
  222. i need some help
  223. CA car--where do the wires to the primary O2 sensor come from?
  224. anyone know the resistance specs on the temp sensor
  225. 2002 Civic EX Coupe FI Relay Clicking
  226. Car Won't Start after Catalytic Converter change.
  227. EVAP system problem
  228. 2003 Civic Lx 1.7 SOHC NON-V manual trans.
  229. How long does a new head gasket last?
  230. 2002 civic ex: Mystery gasket/seal
  231. Engine light question
  232. 2004 Civic LX
  233. ? about replacing thermostat
  234. Random Misfire codes and other problems
  235. changed upstream 02 sensor cel still on
  236. Questions about gas cap or "cap, Fuel filler"
  237. 04 Civic Ex - Blown Head Gasket 158xxx - Please Advise!
  238. Delay in plugs firing at start, normal?? (video)
  239. CEL On
  240. 2004 Civic EX P0344 Code....
  241. P0344 Timing Belt Change. Help! 05 Civic EX
  242. P1361 after changing sensor..
  243. 2003 si: does it have an A/F sensor?
  244. Engine "knack"
  245. 2001 EX: How to Measure Cam Shaft End Play??
  246. Standard Cracked manifold in '03 LX- Need a bit of advice
  247. Where is all of my oil going?!!?
  248. Timing belt DIY/ TDC question
  249. EGR cleaning additional help
  250. CEL + slow shifting in 04 automatic ex after refueling
