Engine light question
Old Jan 16, 2014
msnden's Avatar
msnden is an unknown quantity at this point
Hi, I am new to the forum so please forgive me if I am not following protocol
I am a long time Honda civic owner (On my 4th one) putting literally hundreds of thousands of miles on them, (never a serious problem), my current civic is a 2002 which we purchased new in 2002 (I get my wifes when she get a new one) I have a question that I hope you can help me with (I did a search but not being a mech. I don't really know what words to use).
Here goes I hope I can make myself clear, the other day my engine light came on, NOT the maintenance light, this lite is the one on the left & is a picture of an engine. I looked in my Manuel & it said it could be that the gas cap was not put on correctly, I check & yes it was not tighten, so I screwed it in until it clicked a couple of times, I went and filled up with gas & made sure the cap was properly screwed on, The light is still on, can anyone help with this? or could you direct me to the proper area on the forum to go to.
Thanks msn
Old Jan 16, 2014
GolNat's Avatar
Prelude Owner
Re: engine light question??
Best option: You should reset it with a scan tool, which is free at parts stores like autozone.
An option but may have radio issue: disconnect the negative battery cable for a couple minutes, that will reset the computer but may cause your radio to reset needing you to get the radio code.
If it comes back on go get it scanned for free at autozone or other stores that offer free scanning.
Old Jan 16, 2014
Welcome to the forum.
What is the code?
Get the code read and post the code numbers here.
Old Jan 16, 2014
JJ291's Avatar
No amateur/no professional
JJ291 is an unknown quantity at this point
Re: Engine light question
That is the Check Engine Light (CEL). Your car is alerting you that something is wrong with it's operation. If you go to a local autoparts store and have them connect a scanner (or spend about $45 on a scanner and connect it yourself under the driver side of the dashboard), you can get the correct error code. Once you know the error code you will have a better idea of what is wrong.
If you get the code and post it on this site you will probably get better help because just the light by itself does not provide any information unless something is wrong with the car when you drive it and you can describe it in detail.
Old Jan 16, 2014
Consolidated posts and threads, deleted duplicate post
hernandexz
Oct 28, 2021 10:52 PM
thana
Jun 15, 2020 07:05 PM
jetcare101
May 8, 2015 01:33 PM
Flipg123
May 8, 2015 01:15 PM
tylerginevan
Apr 27, 2015 12:29 PM
