O2 Sensor '03 Honda Civic EX
Old Apr 10, 2013
staceyh711's Avatar
staceyh711 is an unknown quantity at this point
So I need to change the front O2 sensor on my civic but I haven't been able to get a confirmation whether it's located on the top or bottom of my engine. Can anyone send me a diagram or picture on where it's located? My car is starting to put-put and it's getting really annoying.......
Old Apr 10, 2013
Re: O2 Sensor '03 Honda Civic EX
Jack up the car, it's just after where your downpipe makes the 90-ish degree bend
Old Apr 12, 2013
palsana's Avatar
palsana is an unknown quantity at this point
do not splice the wires when installing those O2 sensors. Use only Denso Oxygen sensors direct fit. Speaking from experience installing all different brand O2 sensors in exactly the same 2003 Honda Civic Ex car.
Old Sep 12, 2014
skipcfd's Avatar
skipcfd is an unknown quantity at this point
I'm having issues after replacing both O2 sensors on my 03 EX. I resettle computer with my OBD2 computer but the check engine light comes back on with the same error code. Any thoughts??
Old Sep 12, 2014
The brands of O2 sensors you bought were ________?
The code is _______?
Old Nov 19, 2014
skipcfd's Avatar
The front 02 sensor is at the bottom of the motor. The wiring harness runs along a cross member behind the engine fan.
Old Nov 19, 2014
skipcfd's Avatar
The Brand of sensors was Bosch
The code was P0141
I had the sensor tested and they determined it was a bad sensor. So I took it back and got a new one. Reset the computer and the light came right back on. I am wondering if it is the catalyst converter?
Old Nov 19, 2014
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
Problem solved, wrong sensor. Bosch = German, Honda = Jap.
Go get the right sensor, as in, NTK or Denso. Go to the Denso website and find the right sensor using the vehicle selection tool!
Old Nov 19, 2014
Throw away the Bosch sensors.
Get the correct DENSO or NTK sensors, whichever brand came in it from the factory.
The code was P0141
P0141 has nothing to do with the front O2 sensor.
P0141 is for the REAR O2 sensor, "a problem in the heater circuit" to be exact..
Again, use the correct brands of sensors.
That would be code P0420.
Pr0n1s
Apr 30, 2015 03:08 PM
jessicakaybby
Apr 20, 2015 12:11 PM
ashleymmackey
Apr 18, 2015 09:48 PM
dooner24
Apr 14, 2015 07:51 PM
