2005 civic p2227 code
Old Oct 20, 2018
dabatman99's Avatar
dabatman99 is an unknown quantity at this point
So recently I replaced the engine in my sons 2005 civic dx from a 2002 civic dx. I took off the intake and swapped it over so everything will still be compatible with the EGR. Finally got it running. The only issue we noticed after a short period of time was it has a high idle usually between 2200 when cold and down to 1500 when warm. Checked and found a p2227 code. It has to do something with the barometric pressure. Anybody have any ideas? Could it be a leaky intake or a bad MAP sensor?
Old Oct 21, 2018
GolNat's Avatar
Prelude Owner
Re: 2005 civic p2227 code
Could be a leak in the intake somewhere I would check that first.
Old Oct 21, 2018
mikey1's Avatar
agreed.....
sounds like its sucking in air from somewhere it shouldn't be, that would cause a high idle
could be a leak between the head and the intake manifold
Old Oct 22, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Your PCM may be incompatible with new donor engine.
antony1103
May 10, 2018 07:53 PM
Farticle69
Aug 6, 2015 08:02 PM
knightmare
Sep 26, 2010 11:08 AM
hatE
Engine Swaps
May 25, 2006 06:57 PM
Wizkid
Jan 3, 2006 07:32 PM
