05 EX P2646 problem
Rep Power: 0 05 EX P2646 problem
So I've got an 05 civic EX.
had a vicious oil leak and Honda dealer confirmed to be a faulty vtec solenoid (spool valve) I had previously changed the gasket on it about half a year ago. Honda dealer says that its leaking internally pushing it out.
Took car and had vtec solenoid and gasket replaced new. Bought a remanufactured one on eBay. They are identical to the old one even the gasket.
drove car for maybe 25 minutes and check engine light comes on, scan it and find P2646 and P2647. Reset the light and it came back on about 10 minutes later.
did forum reading, read that low oil could be the cause. Car needed and oil change so had the oil changed and reset the light again. Only P2646 came back and remains.
I'm not sure what's happening, I'm out of ideas. No other work were preformed on the engine other than this valve replacement. I've had an oil change, new filter, fresh oil topped off to proper amount.
PLEASE HELP!!!
This is also causing car to stay in limp mode, car will not move past 4k RPM. When you reach 4k is like it's being governed.
Is it still safe to drive?
PLEASE HELP!!!
Re: 05 EX P2646 problem
May need an OEM Vtec solenoid. There are 2 gaskets - make sure they are clean. Low oil or restricted oil filter can cause this code. Try searching on P2646 on this site for more threads and info.
Rep Power: 0 Re: 05 EX P2646 problem
What I got was a remanufactured OEM valve, car has oil with less than 100 miles on it, and brand new filter. I've spent over an hour on this forum and on google. I've read something about a screw/bolt on the inside of the head bit we never messed with or even took off the valve cover, the other is doing continuity reading on the pressure sensor at 3000rpm, which shouldn't be necessary as the the sensor on the new valve is brand new.
Put the original vtec valve back on it.
Erase codes.
Drive it.
Codes gone now? (assume yes)
Now fix the leak. Does the vtec valve just need the upper gasket?
Erase codes.
Drive it.
could put the old one back on but it still leaks real bad, thus the reason I changed it in the first place.
If the problem is handled will this code go away in its own (light goes off) or will I have to clear it on my own.
Search the forum, I've posted the part number for the upper gasket the dealer catalog doesn't show, many times.
Battery disconnect should erase engine codes.
The main gasket in this set is the one that I used. Is this smaller one, the one I need?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F17 3233307894
Accord to the part number you posted it says it doesn't fit my car.
Now you see why the dealer can't replace the leaking upper gasket------ because it doesn't exist in the dealer parts catalog when you look it up for that car, therefore they must sell you the entire valve.
The dealers parts catalog does NOT make it easy to figure out interchanges, like what dealybob can be used to fix another thingy.
We had to go back several years in the parts catalog to locate the upper gasket, and someone had to actually order it up and try it to confirm it actually fits on the D17 engine
URL fail
That's absolutely correct.
Alright, the part DOES show up on the hondapartsnow.com catalogue but as previously stated it does say "This part does NOT fit your vehicle" I'm just now seeing the broken link on the post I had previously made. I'll try a different approach here with that. I DID tell my mechanic to save the original Vtec solenoid so that we can try to repair it.
Image of the solenoid is the style I have on my vehicle. Little searching online yielded this other image of the gasket I replaced PLUS this smaller one. If I'm hearing you correctly, THE SMALL one is the one I need to replace to stop my leak?
Today we reinstalled the OLD original OEM valve assembly, swapped the new pressure sensor over and changed the gasket on the top portion. Put engine parts back on and cleaned everything off and cleared the code. Drove it and took it to vtec 5 or 6 times and the light has NOT come back. I guess there was something wrong with the re-manufactured valve I bought on eBay, so after cannibalizing it for parts I'm only out 35$
If it wasn’t for non-oem quality parts on the market, this forum would be a ghost town.
Awesome you were able to salvage out a functional seal to fix your old valve.
Kostanky
04-22-2017 09:27 AM
Kostanky
03-18-2017 12:54 AM
