Cold start
Old Feb 9, 2019
Chbronco's Avatar
Chbronco is an unknown quantity at this point
Cold start
My 2002 Honda civic lx sedan runs perfect.but when cold wether -25 very hard to start, try 3-4times in a minite wait 15 minutes try again finely on the 7th cycle will start any ideas?
Old Feb 9, 2019
Slumpertcivic's Avatar
Re: Cold start
Move to Houston, Texas and never worry about -25 weather..
Old Feb 9, 2019
Chbronco's Avatar
Re: Cold start
Ya ok,have read may need new spark plugs
Old Feb 11, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Cold start
Block heater
Gasline antifreeze
Keep fuel tank above half full in this weather - reduces condensation in the tank
Old Feb 11, 2019
Re: Cold start
Seriously though, super cold weather can easily make aged fuel injectors leak or stick.
I personally would see if turning key to on, pushing the gas pedal all the way down, then cranking for 10seconds, then releasing the gas pedal makes any difference in the startup.
Next I would pull the up stream O2 sensor to see if the catalytic converter is causing too much back pressure.
Old Feb 11, 2019
Chbronco's Avatar
Re: Cold start
Thanks guys
Old Feb 11, 2019
Chbronco's Avatar
Re: Cold start
Slumpertcivic is that replace the 02 or take it out completely. No engine light on.
Old Feb 13, 2019
Re: Cold start
It’s a simple way to “relieve” some excess back pressure if the catalytic converter has started clogging up.
Clogged up catalytic converters won’t necessarily toss a code, and you likely wouldn’t even notice a huge loss of power as the car never really had power in the first place.
But as they get bad, hard starts is common result.
Old Feb 14, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Cold start
If you have a second car try jumping the car with the issue. If it fires up right away then you know the battery is being drained by the cold.
If so buy a battery tender.
Old Feb 14, 2019
Mikeyyy's Avatar
Mikeyyy is an unknown quantity at this point
Re: Cold start
What does your car do when you try to start?
Turn over slowly? or just take a while to start??
Old Feb 14, 2019
Chbronco's Avatar
Re: Cold start
Above-20 Celsius will start farley easy, below-20 different story..Like I said try to start 3-4 times wait 15 minutes, try again .Doing this cycle about 5-6 times will finally start,each cycle seems to get closer to start.Battery is good.
Asblasor
Jan 12, 2018 12:18 PM
gdm129
Jan 28, 2014 08:28 AM
Asblasor
Aug 23, 2012 03:40 PM
jackastor
May 26, 2002 03:10 PM
NitehawkVTEC
Mar 7, 2002 12:14 AM
