What's this squeal?
What's this squeal?
I noticed an annoying squeal has developed and i'm trying to get some help, determining what needs my attention.
It is mostly heard from a stopped position, starting when you give it gas up to about 40-50km. Turning the wheel while accelerating, like at a stop sign, seems to make the sound louder.
With the car stopped i can't reproduce the sound by turning the wheel and i have power steering fluid.
The AC On/Off has no impact.
Revving does not reproduce the squeal
What can i check next?
2001 civic 127000 km
Thanks,
Thanks,
Re: What's this squeal?
Check your belts, most likely power steering but you'll probably find you need to tighten the AC belt as well
WWSWD?
I'm no expert but my car would squeal when it was stopped. Going faster seemed to help sometimes but noise wasn't really speed dependent as I could have it at idle. I'm wondering if it's ball bearings going. For me it was my AC compressor bearings.
Thanks everyone for your input.
I tightened the adjusting bolt 3 revolutions and tested.. And did this 3x for a total of 9 revolutions Pretty tight about 1/4 inch play.
The annoying sound has reduced about 75 percent.
Im wondering if a new belt would address the remaining 25 percent ? Or tighten the current one up more? It's dark so I had to stop
I also sprayed some silicoln spray on the belt before this which made no difference when driving.
Inspect the belt that's on there now. Is it cracking or anything that would warrant replacement?
It still needs to be tight enough to stop the noise. Give it a few more cranks and try it. If it's still noisy tomorrow, tighten a little more..
You would have to go waaaay beyond that to damage bearings.
The bearing in the compressor pulley wears out without overtightening the belt.
The sound has gradually returned.
Some days it's quiet and some days it really squeals, and turning becomes a bit stiffer when it squeals. Im starting to notice a trend where its worse when its damp outside.
I noticed the power steering fluid, although it has a couple inches in the 'reservoir' it is just under the 'lower level' indicator.
What steps would you recommend next ?
you may need to tighten the belts again, sometimes they stretch after a while, especially if you used aftermarket belts, and top up your fluid
mishbha
May 18, 2010 05:26 AM
BlueNothings
Nov 28, 2006 03:30 AM
VTECTypeR
Jun 2, 2003 07:19 PM
