Marks on timing belt don't line up. Normal?
Hello again, Civic Gurus! Maybe it's normal, but I'd rather check in before bending valves. Here's the deal:
Whilst removing my cylinder head, I marked the timing belt and its corresponding spot on the cam sprocket. I made sure to get it back on in the same place, which was way more annoying than just putting it back with proper tension. Cam and crank were TDC the whole time.
I got it all set up, rotated the crank pulley a few times, and back to TDC. My mark on the timing belt doesn't line up, but both cam and crank timing marks are at TDC. Did I screw something up? Or does the belt length keep it from being perfectly lined up?
I changed my timing belt a couple of months ago, and it still looks great. I didn't mark the belt and cam then, so I don't know if I messed something up this time around...
Re: Marks on timing belt don't line up. Normal?
Read a real service manual for correct information!
The service manual does not tell you to make marks on the belt.
You'd have to spin the engine about 173 times before marks you made on the belt line up again.
Thanks dude! I'm just worried that I'm leaving something out.
Funfact: I didn't realize I had to do the valve seals with the head off, and I already got the head back on... I'm going by the Honda service manual, but I'm still an idiot. I try to supplement with forum lurking, YouTube videos, and posting when I can't find what I need.
Thanks again!
Thanks again!
Simpson5774
Sep 29, 2014 07:23 PM
forevermemorabl
27
Sep 20, 2013 11:01 PM
wk9k
Mar 13, 2012 09:04 PM
