TSB pertaining to P1457 Error code
Old Sep 30, 2018
dcb1018's Avatar
dcb1018 is an unknown quantity at this point
Where can I find the TSB pertaining to P1457 error code? Is this something Honda has to fix or is it my responsibility?
Old Sep 30, 2018
Re: TSB pertaining to P1457 Error code
You own the car and the warranty expired long ago. Fixing it is your responsibility.
The only thing Honda takes care of for you now is recalls. (and some mechanical seat belt failures)
Search the forum for your code number, and google search. Tons of info is available.
99% can be solved using the diagnostic steps in the service manual.
The most common issues I see were already mentioned in your original thread.
https://www.civicforums.com/forums/3...-lx-p1457.html
Old Oct 1, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
You will most likely need to replace the EVAP By-pass (Canister) Shut Valve (CVS) and the EVAP Canister (bolts will be rusted to warrant replacing too).
See the attached TSB...
File Type: pdf
Old Oct 1, 2018
In 15 years I think I've only installed one of those TSB kits that actually fixed the car.
All the rest were unrelated to the TSB.
JD101
Oct 13, 2017 08:44 AM
Civic15
18
Sep 19, 2017 07:48 PM
bulls2030
Sep 14, 2017 07:56 AM
dizzle428
May 7, 2012 03:54 PM
fuledya
Oct 27, 2006 03:39 AM
