2005 civic-cel code p1457
Old Sep 13, 2017
bulls2030's Avatar
bulls2030 is an unknown quantity at this point
I have a 2005 Honda Civic LX 4dr Automatic with about 110k miles on it. Have owned it since 10k miles.
The check engine light has been on for a while and it is time for emissions. The code I have is P1457.
It was recommended to me by a shop that I get a smoke test done, but thats costing me around $90 so I'd rather see if I can get it fixed.
Can anyone help me of what the most common causes are for this code and the most common fixes (replacement parts)? I would like to get it fixed right and get the code cleared.
Also, if you could recommend where is the best and most economical place to get the parts.
Thanks!
Old Sep 14, 2017
mikey1's Avatar
Re: 2005 civic-cel code p1457
i had that code,
it was my EVAP cannister valve, replace it
Old Sep 14, 2017
bulls2030's Avatar
If it helps, I used a smartphone OBD tool. Here is the screenshot of the code and some other information
https://imgur.com/a/aIvi1
Old Sep 14, 2017
bulls2030's Avatar
Originally Posted by mikey1
i had that code,
Thanks! Did you use an aftermarket part or a genuine honda part?
I am on rockauto and I see: Vapor Canister, Vapor Canister Purge Valve, and Vapor Canister Vent Valve. Which one is the one you said you replaced?
Thanks for your help!
Old Sep 14, 2017
mikey1's Avatar
i used OEM honda,
not sure of the exact name, but there is only one valve attached to the cannister bottle, so thats the one,
