Unkonwn Problem. Ticking noise , civic 2005 196k
Old Feb 27, 2019
hazarinoor's Avatar
hazarinoor is an unknown quantity at this point
Hi,
I bought this 2005 civic a few days back. It's cold here in this part of the US so that the heater was on while test driving. Due to this reason, I didn't hear a periodic noise comes around the engine.
Can someone suggest to me what it could be? I have attached a bad quality video file. But the audio is okay. Also how do I check the timing belt is okay or not. Any easy way to do that.
Old Feb 28, 2019
Colin42's Avatar
Re: Unkonwn Problem. Ticking noise , civic 2005 196k
sound like the valves might need to be adjusted
Old Feb 28, 2019
hazarinoor's Avatar
So that's nothing to do with the timing belt. Does it require immediate attention or I am okay to drive? Thanks
Old Feb 28, 2019
Colin42's Avatar
if you don't know when the belt was last changed you need to get that dealt with as soon as you can, use honda parts, belt, tensioner, and waterpump.
the belt is overdue by the age and mileage of the vehicle and its basically a ticking time bomb.
the valves should be checked as soon as you can as well because you could wear out parts prematurely, however it's ok for a little bit
dustyballs
Jul 27, 2017 07:30 AM
eager2learn
18
May 29, 2017 06:01 PM
LeadPipeFill
Aug 13, 2016 07:50 AM
Dave Brabant
Oct 17, 2015 06:38 PM
jimmyjames1387
Feb 15, 2013 11:57 AM
