noise from timing belt area
https://www.youtube.com/watch?v=Mtrl...ature=youtu.be
anyone know what this could be? it only does it from 1000-1200rpm and yes i know i need a valve lash adjustment its happening tomorrow along with this part whatever it is
Re: noise from timing belt area
I take it you don't know when the timing belt was last changed? It's supposed to be 7 years or 100 000 miles. If unknown good idea to change it.
I can't really tell much about what noise your referring to in the video.
Still can't tell what your on about in the video. RPM specific on mine in the past have been heat shield rattle. The heat shield under the seat area of my car is now being held on with a O ring clamp on one end and wire on the other. Also right there I have a PS pulley that makes a wheezing noise unless I hit it with some WD40 from time to time.
I'm sure it sounds plain as day to you in the video but not to me.
The whir sound? Can you feel it in the lower timing cover?
Is it quieter with the upper cover installed? (why is it missing?)
Has anyone messed with the timing belt recently?
When did this noise start?
If there's a lot of slack in the timing belt it may contact the timing cover
If the timing belt is too tight it can howl
no timing belt is probably due it did start after letting it warm up for fifteen minutes it has to start somewhere lol when engines run i can hear every little noise so trush me when i say that when it started . ppl on youtube all had the same noise whine the belt was due
tavisc
Sep 15, 2015 07:46 PM
Joethornton
Aug 7, 2015 09:53 AM
