Crank shaft position sensor
Old Sep 29, 2018
Graphite07's Avatar
Graphite07 is an unknown quantity at this point
2003 Honda Civic 1.7!motor Ex. I replaced the crankshaft position sensor and i still get the check engine light and code
p0336. So I took the sensor back and exchanged it for a new one. So after installing this one same deal, check engine light and p0336 code.
What am am I missing to fix this problem?
Pleqse help thank you.
Old Sep 29, 2018
Slumpertcivic's Avatar
Re: Crank shaft position sensor
Your missing that some (almost all that seek out help on this board) cars seem to require a actual Honda sensor from a Honda dealer to work right.
Also 1/4 can spray contact cleaner on both ends is my recommendation when replacing.
Old Sep 29, 2018
Graphite07's Avatar
so I need a OEM sensor from Honda for it to work properly?
Old Sep 30, 2018
No, but you might have to try a couple different brands of aftermarket till you find one will work for you.
Dealer ones work 99.something% of the time.
Old Sep 30, 2018
Also, those sensors are fragile as crap. I accidentally overtorqued it once and it made it crap itself. Handle that thing like an egg. Drop it, it's probably not gonna work.
Old Sep 30, 2018
Graphite07's Avatar
I didn’t drop it or over tighten it! I do not want to take it back apart!! This sucks I really want my car back on the road.
I guess ill I’ll be pulling it back apart today.
GotU420
Sep 10, 2018 07:09 PM
TD29064
General 7th Gen
Jul 18, 2018 07:16 AM
Rob A Gonzales
Transmission
Jan 24, 2018 03:51 PM
sekhonjatt
Feb 27, 2013 10:25 PM
mullinad
Jul 29, 2002 09:57 PM
