Suggestion needed, Oil leaking:Replace valve cover gasket and thermostat housing
Hello,
I notice the oil on the ground today, and open the hood, notice the oil on the left side and at bottom. I checked coolant, lower than "min" and I filled it up. Then I check the engine oil level, seems ok. It seems like the oil is spay from center, but mainly toward left.
Here is the picture: https://imgur.com/a/ejLs4n9
went to a shop, they inspect it for a few minutes and said both oil and coolant are leaking. need to replace the valve cover gasket ($100 parts+$100 labor) and thermostat housing ($50 part + $100 labor). I prefer to get parts from dealer (but let them keep the profit for the parts, shop don't allow.
Question:
1) is it diy work or it's better to let mechanic to work on it?
2) does dealer part matter that much?
Thank you!
Question:
Thank you!
Re: Suggestion needed, Oil leaking:Replace valve cover gasket and thermostat housing
DIY for sure, and yes buy the parts from Honda, many of the aftermarket valve gaskets kind of fit but not really.
-Valve cover
https://www.youtube.com/results?sear...sat+2001+civic
-Thermostat housing
-Valve cover
-Thermostat housing
hokiedad4
Jan 20, 2015 10:19 AM
Dornblaser1
Nov 12, 2011 05:44 AM
