Timing Belt/Possible valve damage
Old Feb 20, 2019
john_rodgers321's Avatar
ol’ unreliable
john_rodgers321 is an unknown quantity at this point
2003 Civic LX, I started my car in -20 F temp. I let it run for about ten minutes and took of to work. About two miles down the road, I heard a small pop and hiss from the engine, and lost all power/engine died. I did not hear any metallic clanging or anything of the sorts. Upon inspection a few days later, I saw my timing belt had snapped. I have taken everything off (snapped belt, timing belt tensioner, water pump). Was wondering if I could line up the cam and crank to their respective marks and attempt to hand turn the engine to feel resistance from possible bent valves. If so, if there is no resistance should I try to start the car? Trying to avoid taking the head off being as it’s cold as hell outside. Any advice welcomed
Old Feb 21, 2019
Slumpertcivic's Avatar
Re: Timing Belt/Possible valve damage
These questions are complicated.
Since the valves would already be bent, spinning by hand likely won’t diagnose anything.
Old Feb 21, 2019
Why did timing belt fail?
Before removing the water pump and tensioner (assuming neither directly caused the belt to fail), I would have got a new timing belt (what's that cost, 25 bux or so?) and install it. Assemble enough to start the engine.
If engine does not run or runs horribly bad (dead miss), you lost. Bent valve(s), major work ahead.
If engine runs on all 4 cylinders, reassemble it completely and go buy some lottery tickets.
Old Feb 21, 2019
ol’ unreliable
How do I get the cam and crank aligned correctly? When turning the camshaft, it sort of jumps from one spoke being at 12 o’clock to the next. I don’t think this is normal but not positive. I also don’t know how to go about repositioning my crank to the mark on the block, do I need to reinstall the pulley?
Old Feb 21, 2019
It looks like you already managed to take a bunch of stuff apart without a proper service manual.....what next?
Old Feb 21, 2019
sidefly's Avatar
sidefly is an unknown quantity at this point
I found it easiest to use the pulley to turn the crank by hand, make sure you do it counter clockwise. Remove your spark plugs to reduce resistance, it should be easy to get the marks aligned.
Old Feb 22, 2019
ol’ unreliable
I have the new timing belt, tensioner, and water pump on, with the crank and cam lined to TDC marks. However, i was wondering if the #1 piston has to be at TDC on the compression stroke. In addition, is there anything preventing me from doing a compression test on each cylinder before reinstalling spark plugs and valve cover? I feel like I am nearing the end of this repair, but because the belt snapped I want to take every precaution to prevent any/further damage to the engine.
Old Feb 22, 2019
Pistons just go up and down. TDC is TDC.
The cam lobes opening and closing the valves at specific times are what determines which part of the stroke/cycle each piston will be doing as it moves up and down.
Just follow the service manual to install the belt correctly.
Timing belt must be correct first.
Because the life of a timing belt depends on it staying CLEAN ---I'd slap the valve cover on with a couple bolts just so oil doesn't get slung all over the place and contaminate the new timing belt while you are cranking the engine for the tests.
Only if there's no bent valves! Cross your fingers and pray to the deity of your choosing
Old Feb 22, 2019
ol’ unreliable
Thank you for the response, I will update everything tomorrow.
Old Feb 23, 2019
ol’ unreliable
The car is alive. After reinstalling the alternator and power steering, I tried starting the car, and it started. Unfortunately, there are some sounds I don’t recall being there before the repair. There’s sort of a howling sound near the belts ( alternator+ power steering) and a rapid ticking from the engine. Leads me to believe I might have some valves that might not be in A1 condition.
Old Feb 23, 2019
Okay but does it still run on all 4 cylinders now?
No dead cylinder miss?
Check engine light is not flashing while running?
No fault codes?
Old Feb 23, 2019
ol’ unreliable
No fault codes?
The check engine light is not on, and there aren’t any codes popping up on the scanner. How do I check if it’s running on all four cylinders?
Old Feb 23, 2019
The check engine light/misfire code(s). Most people would notice it runs damn rough if it had a dead cylinder.
How long did you let it run?
Old Feb 23, 2019
ol’ unreliable
A good 15 minutes, long enough for the car to get up to temperature. It doesn’t sound rough, the ticking has me worried though.
Old Feb 23, 2019
No misfire detected then. Go buy lottery tickets LOL
Stethoscope to pinpoint noise source area?
Could it have been making noise all along but suddenly you're super critical of every little thing now?
Old Feb 24, 2019
ol’ unreliable
No misfire detected then. Go buy lottery tickets LOLStethoscope to pinpoint noise source area?
Oh I’m not sure, I probably am being critical... just happy the car runs! I thought for sure I would’ve messed SOMETHING up taking on a repair like that. I’m 18 and have only just started working on cars so this repair felt like something a little bigger than what I could take on
Old Feb 24, 2019
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
dude, spend some time and watch piercedasians timing belt video on YouTube. It is an excellent tutorial for a beginner.
felicianojerome
Sep 21, 2019 04:50 PM
Tutty6
18
Aug 31, 2017 09:37 PM
Tim2
29
Aug 9, 2016 09:13 AM
dariusld
Feb 7, 2014 03:30 PM
lilhuff
Nov 18, 2011 06:11 AM
