Changing a front motor mount on MT
Old Apr 9, 2016
wonderingmaybe's Avatar
wonderingmaybe is an unknown quantity at this point
Hey all I have a 2004 Civic EX manual transmission. A dealership did an inspection on my car and two things I should get done are to replace the front motor mount and the front control arms. After some research, I think I can do the front motor mount myself.
The mount itself is about $60. But I am not sure of what tools I need
I cant find anything online that has a step by step how-to change a front motor mount on a manual transmission that also lists what tools I need.
Anyone mind telling me or linking me to a guide? Thanks!
Oh also, should using the same hardware from the old mount should be OK for the old mount
Old Apr 9, 2016
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Re: Changing a front motor mount on MT
I reused my motoe mount hardware. Unless yours is damaged you should be fine resuing. Just use a jack and a piece of wood under your oil panl to take weight off front mount while you replace it.
Front control arms are easy to do. You'd need to use a ball joint removal tool and then its just a couple of 19mm bolts and the sway bar end links. End links can be a pain, might have to cut them off and replace. Depends, but if you have to cut them, its time to replace them anyway. Use Amzon or Rockauto maybe for control arms, end links.
Old Apr 9, 2016
Hydraulic jack under oil pan with a piece of 2x4 between the jack and oil pan. Jack up engine slightly to support it. Unbolt old mount, remove. Place new mount in, insert bolt, tighten down. Lower and remove jack. Done.
I forgot what size socket you need. Prolly 17 or 19mm
Old Apr 10, 2016
Hey!
Thank you both for the responses. Do you guys know what the torques for the bolts will be? I read on another board that it is 47/40 for the two different bolts. Just wanted to make sure this is correct.
Old Apr 10, 2016
mikey1's Avatar
exactly this, its pretty easy as long as you support the engine properly
Old Apr 10, 2016
Creager's Avatar
Creager is an unknown quantity at this point
I did this last week during a clutch install. Might not need to support the engine, if you're only doing the one mount. Mine hangs there and "neutralizes" quite nicely without the jack.
47ftlbs on the bolts
Old Apr 14, 2016
Hey again!
I finally got my parts today. When I inspected the front motor mount that was sent to me, there were two openings in the rubber part. The two cuts look like they are actually a part of the design of the mount, but I just wanted to make sure before installing it.
Also, im curious why new mechanical parts always look so beat up @_@
Here are some pictures.
http://imgur.com/a/7RxmC
Old Apr 14, 2016
yeah, they're (the two openings) supposed to be there. It's to increase vibration absorption transferred to the chassis. A solid rubber mount would make you feel the vibrations much more
Old Apr 16, 2016
Changed the mount! It took 3 hours because the breaker bar wouldnt fit into the car and we had to improvise...
Here is a picture of the old one
http://imgur.com/a/bRlcX
The only problem is the check engine light is now on(I think from the oxygen sensor) and I couldnt torque the bolts on because the wrench would not fit either..So gotta head over to oreilys and get it checked out.
Thank you all for helping
E Sully
May 1, 2016 11:57 AM
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
chilling_pete
Nov 5, 2015 10:05 PM
Cadwallader
Nov 5, 2015 12:32 PM
onelifetolive
Bolt-on Engine Performance
Nov 10, 2001 10:58 AM
