Motor and Transmission Mounts?
Old Nov 2, 2015
E Sully's Avatar
E Sully is an unknown quantity at this point
I have a 2004 1.7l Civic EX with AT. It seems time to change the engine and transmission mounts. I would like to know what is recommended, OEM Honda or are there good aftermarket. Any good threads on this, and could someone refer me to a good diagram with the part numbers?
Old Nov 2, 2015
MassCivic's Avatar
MassCivic is an unknown quantity at this point
Re: Motor and Transmission Mounts?
Definitely go OEM, aftermarket mounts are vibration city! Try http://www.hondaautomotiveparts.com/ my front mount from them was about $49
Edit: link to parts diagram: http://www.hondaautomotiveparts.com/...8AT%29+%281%29
Old Nov 2, 2015
E Sully's Avatar
From what I see, would parts 1,2,4,and 8 be the necessary ones?
Old Nov 2, 2015
MassCivic's Avatar
That's all of them, unless any of the bolts need replacing. Are you sure they're all bad? Usually the front one goes. The rear is a pain to get to.
Old Nov 6, 2015
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
This times 10. The cheapo amazon ones will have your car rattling like a truck. It's about the only part (other than fluids) that you HAVE to go OEM.
Old Nov 7, 2015
E Sully's Avatar
Thanks all. I have ordered Honda OEM mounts for the front engine and passenger side transmission. Front mount rubber is gone and transmission mount is cracked. They will be in on Monday. Should make for a smoother ride.
Old Nov 7, 2015
MassCivic's Avatar
Sure will, just don't forget to support the engine before you remove any mounts! A jack with a piece of wood across the oil pan works well.
Old May 1, 2016
AP4114's Avatar
AP4114 is an unknown quantity at this point
I have a 2004 lx with only 64,000 on it nd have to replace motor mounts if the oem the best that sucks! Another poor quality part-s from Honda
Old May 1, 2016
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
I've done a lot of little things on my 01 LX over the last 2 years. The motor mounts made a huge difference. I replaced both front Lower Control Arms and that made a big difference too.
You can always email Majestic and ask for the best deal on the mounts. I did that on my timing belt kit. I asked for seals and the rear trsnny mount. I told them I'm a vet and served during a war.
They gave me a discount.
Old May 1, 2016
E Sully's Avatar
I replaced the motor mounts with original from Majestic, the Beck/Arnley control arms with bushings and ball joints, Aisin timing belt kit, from RockAuto.
Everything is working well so far.
wcodyd
Exterior
Jun 22, 2015 11:24 PM
charlios
Nov 28, 2001 10:29 PM
vistec
Nov 9, 2001 05:12 PM
mattskav
Nov 8, 2001 10:44 PM
slikor
Nov 1, 2001 04:13 PM
