2001 replaced broken cam sensor now has noise
Old May 1, 2016
Alegations80's Avatar
Alegations80 is an unknown quantity at this point
Have a 2001 civic ex, had a mechanic do the water pump also did the timing belt kit. When he was putting it back together he broke the cam position sensor. he tried jb welding it guess it held at first. After test drive seamed good. Then when and payed. On way out I noticed that I was bogging out pretty bad. That's when he told me that the sensor is broke and need replacing. Long story short I ended up bringing it home and replaced the sensor myself. Now when I try to start it, makes and horrible loud grinding metal to metal sound. Any idea what it could be?
Old May 1, 2016
Re: 2001 replaced broken cam sensor now has noise
Post moved.
If the mechanic tried to cover up a broken sensor, what else could have happened?
Can you account for all pieces of the old sensor, none left inside the timing belt area?
Return to mechanic, see what he says?
chadzeilenga
Nov 20, 2015 12:15 AM
Robert Hamilton
Nov 5, 2015 10:38 PM
bashea
Nov 3, 2015 02:06 PM
upnorthguy
Oct 30, 2015 11:26 AM
Lopezsoul
Oct 29, 2015 08:30 PM
