Engine noise when under load
Old Apr 5, 2019
DaveS's Avatar
DaveS is an unknown quantity at this point
Hi folks,
I have a 2007 Civic, 1.8 petrol
I've recently noticed a noise which sounds like it's coming from the engine. Kind of a chugging sound, a little like a an old diesel. I can only hear it on acceleration or when cruising and only when the car is in gear. Seems more obvous a low revs, up to 3000 or so.
It's not there at all when out of gear. No engine warning lights. No loss of power.
Anyone have any ideas?
Thanks!
Old Apr 6, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Engine noise when under load
Sound clip please.
Old Apr 6, 2019
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
If you could upload a video of the sound it is making, that would be very helpful. Also, this thread belongs in the 8th gen section of the site, but no biggie
Old Apr 6, 2019
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Originally Posted by DaveS
Hi folks,
Quote -
"It's not there at all when out of gear. No engine warning lights. No loss of power."
Thanks!
If the Noise Only ocures while its in gear, then goes away when your out of gear then clearly its in the driveline could possibly be internal transmission problem.
1st thing to check is the transmission fluid Level.?
Old Apr 27, 2019
DaveS's Avatar
Thanks for the replies. I couldn't get a sound clip as you couldn't hear it on my phone over the engine and road noise. Took it to the garage in the end who said the gearbox was on its way out. £550 for a replacement
Old Apr 27, 2019
I'm sorry to hear that, that sucks. The noise could very well be a bad transmission, but maybe there could still be hope. It is possible that something like the exhaust is rattling from vibration when the engine is under load. I had a broken exhaust hanger on my Civic that caused a pretty bad rattling noise, but only when the trans was in gear. I thought that the engine was going out initially until I found the broken exhaust hanger. That may or may not be your problem, but certainly worth considering.
Oh and if this was my car, I would check the transmission fluid to make sure it's full and to check for metal shavings. If yours in an auto, there will be a dipstick with a yellow handle on the top of the transmission. If you have a manual transmission, there is a fill plug on the side of the trans that you would need to remove. The oil level should be up to the fill plug and it shouldn't have glitter in it. I hope this helps and good luck with your car!
Damngoods
Aug 30, 2005 09:36 PM
fixeruper
Apr 28, 2005 02:26 PM
ASIANPRIDE
Sep 24, 2004 02:48 PM
nerd4president
Dec 10, 2003 01:28 AM
