AC and power steering belt tension adjusting
Old Jan 9, 2019
reqy's Avatar
reqy will become famous soon enoughreqy will become famous soon enough
[Edit: Realized I posted this in the wrong subforum. Thought i was posting in the Mechanical/Fix-it Sub. Any mods able to move it to the correct one?]
Hello,
I replaced the AC and alternator belts with OEM replacements but i'm getting a little bit of squeal when i first start the car. I'm thinking it just needs some tension adjustments.
To make adjustments to the A/C / Alternator belt, will i need to remove the Power Steering Pump or are there easier access points to it since the nuts are way down there?
I just don't want to do more work than i have to.
Thanks!
2003 CIVIC EX Coupe.
Old Jan 9, 2019
Re: AC and power steering belt tension adjusting
Belt for alternator isn't tight enough. Adjust tighter, then drive it and see if noise is gone. If noise is still present, adjust the same belt a little tighter.......repeat until it's tight enough to not squeal
If you're old school, these need to be a lot tighter than the old V belts
Old Jan 10, 2019
reqy's Avatar
Ii see. Tyty.
To reach the tension adjusters for that belt will i need to remove the power steering each time? I just recall having to unmount it when i changed the belts and was a little bit of a hassle.
Old Jan 10, 2019
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
No, you do not have to remove power steering pump. You may want to jack up car, remove driver side tire and plastic shield so you can see whats going on down there.
Old Jan 10, 2019
I don't.
Kennykenny
Feb 21, 2019 12:21 AM
EK9Fraile
General 6th Gen
Oct 16, 2018 09:51 AM
FijiEM2
Jul 18, 2017 08:17 PM
brian02
Jan 19, 2011 07:50 PM
hnperez5
Jun 29, 2007 08:29 AM
