Set Proper belt tension?
Old Aug 11, 2010
brian02's Avatar
brian02 is an unknown quantity at this point
What rule of thumb to go by when setting the tension on the alternator and power steering pumps on a 02 civic automatic?
How much up and down play do u want?
thanks
Old Aug 12, 2010
incognyto's Avatar
incognyto is an unknown quantity at this point
Re: Set Proper belt tension?
best bet's to measure how much play you can get before you change it... otherwise just tighten it up and before you put the power steering pump back in just fire up the car and put on the ac and head light's and all the power accessory's you can so there's a load on the alternator.... if the belt sqeek's or slips tighten it a bit more untill it doesn't (of course with the engine off) then do the same with the power steering pump ... but that one's on top so it's ultra easy if it's a bit loose.
Old Aug 12, 2010
jsmithe2010's Avatar
jsmithe2010 is an unknown quantity at this point
I bought a tension gauge at eBay for like $35 a while back 'coz I didn't want to guess and don't wanna keep thinking sheeze, is it too loose? is it too tight? is the alternator not spinning enuff to charge the batt? $35, well worth it, make quick jobs of adjusting, is a "forever" tool, move on to more interesting projects.
Old Aug 12, 2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
Pic or linK?
How exactly do you operate one?
Old Aug 12, 2010
02civicsi02's Avatar
Low and slow!
There should be no sag in the belt what so ever. Just tighten it as tight as you can.
Old Aug 12, 2010
Nosepicker's Avatar
I like this guy. Plain and simple.
Old Aug 13, 2010
If ur kin eyes notice sag, then the (no) charging light would had come on by then.
There are a couple of variation on tensioning gauges, but mine looks like this:
The belt goes between the two fingers and pushes on a center level that u don't see in the picture, the level is spring loaded and calibrated that drives the gauge face.
Old Aug 13, 2010
unless you a body builder, of course!
My friend have some of his tools bent... Hex key is helical now... I would post a pic if i had...
Old Aug 23, 2010
Nosepicker's Avatar
I struggled with this for hours last night. Car's still not done and I'm still unsure about the tension.
I may look into buying this tool.
Old Dec 15, 2010
Suntrana45's Avatar
Suntrana45 is an unknown quantity at this point
I would be very careful on overtightening, you may put enough tension on the alternator pulley to cause alternator bearing failure if it is too loose you will hear it "squeal" like a stuck pig under heavy loading, i.e headlights, heater, rear window defroster, etc.
Old Jan 19, 2011
BobDobolina's Avatar
TRUST me! I'm Idiot Proof!
BobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura about
Hello everybody! First post!
Im sorry for breaking into this thread but I have alot on my mind, AND pics and dealer pdf guides to post.. and i cant do it...suppose im too new? What gives?
And that guage in the previous post...forgot who at the moment, thats a damn expensive one! Nice! ...makes me think I should pick up a cheapy soon...
Back to why im here:
I am about to do my T-belt VERY soon (all belts, really). OEM parts just arrived in the mail from DCH Honda in Cali, VERY good service/prices FYI. And after a succesful Exedy stage 1 clutch install, rear main seal, transaxle seals and ball joints(watch where you WHACK) reading robo1040's post (with his sexy toolbox LOL) I am ready to tackle it.
Does anybody got advice to give? Also rebuilding the P/S pump...i'll get pics.
FYI I already read Creaker2's DIY, Reddawnman's DIY and a few others...its been pretty slow at work LOL
Thats all folks! Hit me back!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
159
Jul 5, 2015 09:54 PM
silentz
Jun 17, 2015 10:21 PM
Bradel26
May 30, 2015 10:24 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
