General 6th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Belt tension
Old Oct 16, 2018
EK9Fraile's Avatar
EK9Fraile is an unknown quantity at this point
Belt tension
I have a 2k civic ex coupe and I’m trying to figure how to tighten my powering steering and alternator belts. My alternator belt squeals like crazy when I first turn my car on and the power steering a little when I’m turning. I originally thought my belts needed replacement but they seem to be in pretty good shape. If anybody can tell me how to tension my belts that would be swell.
Old Oct 16, 2018
Colin42's Avatar
Re: Belt tension
moved to 6th gen,
loosen bolts for the power steering pump, there's a square hole in the pump bracket that fits a ratchet either 3/8 or 1/2,
use ratchet to rotate the pump to take up the slack,
hold pump in place and tighten the bolts.
should be a similar procedure for the alternator.
can always check youtube.
should probably replace the belts, they're like $10 each
Old Oct 16, 2018
Wankenstein's Avatar
Re: Belt tension
Look in service manual for belt tension deflection distances.
An old school rule of thumb is find the middle point of the longest distance of the belt between two pulleys then twist the belt 180 degrees..tension so that it reaches 180 degrees but doesn't go past.
FijiEM2
Jul 18, 2017 08:17 PM
NathanKeller
Feb 8, 2016 11:49 PM
7thgensurvivor
Aug 28, 2015 08:39 PM
silentz
Jun 17, 2015 10:21 PM
sirux
Buy, Sell, & Trade - Archive
Jul 6, 2010 11:09 PM
