Theoretical Catalytic Converter Work
Old Mar 7, 2015
Ocoee's Avatar
Ocoee is an unknown quantity at this point
02 civic ex, d17a2 enigne, 300,000 miles. I've had the 420 code for about 4 years, guessing the cat is bad. I would never run without a cat, but, if I did.......
If you clean out a cat, will it make the 420 code go away? Will it mess with the O2 sensors and cause a code there? I have worked through a couple of other codes, and would love to see the engine light off before I die.
Old Mar 7, 2015
Re: Theoretical Catalytic Converter Work
Just what are you thinking of?
Old Mar 7, 2015
Ocoee's Avatar
what if you scrape out the inside? Does a $150 walker generic replacement work ok? This is the cat that has the attached header. The generic replacement would require cutting the pipe. Will recycle companies buy one that is cut? Willing to put a little money in this but stock replacement is $1,000.
Old Mar 7, 2015
"Gutting" the cat can't fix the code.
It's cheap for a reason.
Factory part is expensive for a reason.
Cheapo cat may or may not last.
The computer is quite finicky, discount cats usually can't keep it happy for very long.
Hit and miss, I've seen it go both ways.
Warranty normally only covers the part, not installation--- so think about that.
The next step up from Generic would be a cat that is California Certified, should come with a much better warranty and will be a bit more expensive.
Any exhaust shop can weld that replacement in. Standard practice IMO.
I can't answer that.
Do you have to pass an emissions test? (I guess not if you've had the code for 4 years)
Are you a tree hugger?
How much longer will you keep the car? How many miles?
How long does the new cat need to last?
Does the engine run bad?
Does it consume oil?
I hate to even think about posting this..... I'm gonna go hug a tree now.
This is against all federal emissions tampering laws. Do not ever do this. You will pollute! The Cubs won't win the world series! Your babies will be born naked!
^Do not click that link!^
*wink*
Old Mar 7, 2015
Ocoee's Avatar
no emissions test, holy grail is to get engine light off without spending a small fortune
Old Mar 7, 2015
Don't you dare click that link in the previous post!
Old Mar 7, 2015
Ocoee's Avatar
duuuuuuh, oh, that link. lose focus after reading three lines.
Old Mar 7, 2015
Ocoee's Avatar
to answer other questions, car has 300,000 miles, i drive till i shoot it. Seems to run ok but gas mileage slipping
Old Mar 7, 2015
I think you can get meds for that problem LOL
Old Mar 8, 2015
Ocoee's Avatar
Should I test the O2 sensor first?
Old Mar 8, 2015
Do you have O2 sensor codes?
Shakzhussain
May 17, 2015 12:03 PM
BootyDo
May 8, 2015 05:36 PM
jessicakaybby
Apr 20, 2015 12:11 PM
ayzan
24
Apr 17, 2002 06:55 PM
Maximus
Bolt-on Engine Performance
Nov 18, 2001 03:55 PM
