head gasket or cracked head ?
Old Jan 15, 2019
Roadglide04's Avatar
Roadglide04 is an unknown quantity at this point
Is there a way to tell the difference between a cracked head or a blown head gasket without taking the head off?
Old Jan 15, 2019
Slumpertcivic's Avatar
Re: head gasket or cracked head ?
If the head is cracked, which is rare on a D series, it usually would occur around the spark plug hole and valve holes.
The aluminum is too thick elsewhere to normally crack, but if it was run without oil and coolant and got super hot to point it stopped running and then you submerged it into sub zero salt water.. Just saying it would take a huge thermal shock to crack that hunk of aluminum.
Now warping / distortion can happen easily..
Old Jan 15, 2019
TY Slumpertcivic. That does sort of elevate my mood. Normally I would jump out there and yank the head for a new head gasket. But as I'm now dragging around an oxygen bottle due to severe COPD I'm going to try bars leak head gasket sealer. In my mind I'm thinking, if it works well great, if not well I already got problems anyway.
Old Jan 15, 2019
Colin42's Avatar
Do not use stop leak, it will only cause further problems
Old Jan 15, 2019
Maybe so. If it doesn't work, well I was gonna have to take it apart anyway. I may get lucky get once. I know the right thing to do but with this copd it would take me a week or more to do the head gasket. I have heard of Bar's Leak working.
Old Jan 15, 2019
History shows us a blown head gasket is pretty routine, along with anything that happens after the engine gets overheated (warped head, etc).
Cracking a head would be quite unusual.
Old Jan 15, 2019
The only possible way that stuff could work would be if you pulled the spark plugs out and poured it in the cylinders directly.
For the love of your engine and coolant system and heater core, do not use it on a Honda engine.
How far can you go from a coolant fill up till it starts getting to overheat range? Some people can just add water once week or so.
Old Jan 16, 2019
Wankenstein's Avatar
Head gasket sealers can potentially clog radiator and heater core. If the engine overheated then the head is most likely warped out of spec and no amount of stop leak is going to solve that issue.
joel03civic
Feb 16, 2019 09:12 AM
billz28
Jul 30, 2016 10:06 AM
siguy2
Mar 19, 2015 09:10 PM
matthew_burnett
Apr 14, 2012 03:01 PM
Roy
Apr 12, 2002 11:11 AM
