changed upstream 02 sensor cel still on
Old Jan 7, 2014
fouronethree's Avatar
fouronethree is an unknown quantity at this point
so i replaced my front 02 sensor and re flashed the comp and it went off for 10 seconds then came back on. idk what to do now tghe cel wont go away its a brand new oem sensor straight from honda 04 honda civic ex coupe
Old Jan 7, 2014
crxmanpat's Avatar
Pusher Jets Rule!
crxmanpat has a spectacular aura aboutcrxmanpat has a spectacular aura about
Re: changed upstream 02 sensor cel still on
Have you had the code read since changing the O2 sensor? If so, what are you getting now?
Old Jan 8, 2014
GolNat's Avatar
Prelude Owner
Also what was the code before replacing the sensor? The original problem might still exist.
Since you used an OEM sensor the likely hood of that being the problem is minimal.
Old Jan 8, 2014
it read upstream o2 when i changed it and it still says upstream even after i replaced it is there anythng else that could cause that code to come up other than the o2?
Old Jan 8, 2014
mikey1's Avatar
yes,
poor electrical connections and/or faulty wiring
Old Jan 8, 2014
I've never seen a scanner only say replace an o2 sensor, every OBD2 scanner I have ever used in my life all give basic powertrain codes in the standard Pxxxx format.
sharp66
31
Jun 12, 2022 08:45 AM
KillerX
Apr 9, 2017 08:20 AM
juror
May 26, 2015 06:35 PM
Fastfebur
Apr 26, 2015 11:57 PM
dooner24
Apr 14, 2015 07:51 PM
