2003 Honda Civic camshaft position sensor
Old Aug 29, 2016
Carolyn Gilbert's Avatar
Carolyn Gilbert is an unknown quantity at this point
i Have a 2003 Honda Civic. I did a diagnotic on it and the code i got was camshaft posation sensor A Bank ! - ck range /performance. Where is it located and does it have adjustment or just has to replaced? I appreciate any help. Thank you
Old Aug 29, 2016
Re: 2003 Honda Civic camshaft position sensor
Make sure the timing belt is intact, in correct time, and the tensioner has not broken its spring.... sensor wiring is securely connected...
Then I'd probably replace the cam position (CMP) sensor. The wiring that goes through the top timing cover is for the CMP sensor.
You have to remove the valve cover and the upper section of the timing cover to reach the sensor.
Old Aug 16, 2019
Himalayan's Avatar
Himalayan is an unknown quantity at this point
Any update on that? I have the similar code p0341 on 03 Civic LX. The code got set twice under high RPM and below max load going uphill at steady speed of 35 to 40mph on a dirt road.
Old Aug 16, 2019
IIRC, its a magnetic sensor (or similar method of sensing). No adjustment, just replacement. It's a fairly delicate sensor. I had one crap on me by accidentally dropping it. Do yourself a favor and make sure the mounting bolt is torqued properly. Had one vibrate itself loose and go cannibal mode on my timing belt.
Old Aug 21, 2019
Baelfyre's Avatar
Baelfyre is an unknown quantity at this point
I'm having a fairly severe issue with the camshaft sensor.
I bought the car three days ago, and on the way home (private sale) the CEL came on with power loss, shift at 3000 rpm, difficulty starting. Stopped, got the code read and was diagnosed as a bad camshaft sensor. Made sense after checking the net, so replaced the sensor and valve cover gasket while I was in there. Turned over on the first try, ran smoothly for a couple of minutes, and now I'm getting a misfire with a blinking CEL. No oil in any spark coil or wires. I'm nervous to even run it down to the auto parts store to get a reading at this point.
The car ran without a misfire before the sensor was replaced, so it doesn't make sense to me that it does now. What do you guys think the odds of me having gotten a bad sensor at the auto parts store (Advance Auto)?
Old Aug 21, 2019
BrotatoChip's Avatar
Super Moderator
We see lots of people have issues when using with non-Honda replacement sensors. Return your Advance Auto one and replace it with a Honda genuine sensor.
Old Aug 21, 2019
Slumpertcivic's Avatar
Just tossing this out there..
Check the actual timing marks while your back in there.
Certainly possible for a event such as that to “skip the belt” if it and or the tensioner is perished..
Redneck advice, just use a socket wrench with slow even pressure to turn the cam too the alignment marks. If the bottom harmonic dampener marks are nowhere to be seen, spin the cam one more turn.
Also while you have that upper timing cover off make sure the tensioner spring is still attached.
And welcome to the forum!
Old Aug 22, 2019
Baelfyre's Avatar
Where should the timing marks be at for proper timing (near noob engine work; done work on outer parts of the car for years)? The timing belt seemed taut with no play.
Thanks for the help, guys!
Old Aug 22, 2019
Super Moderator
https://www.civicforums.com/forums/1...ne-timing.html
Old Aug 31, 2019
Sparknos's Avatar
Sparknos is an unknown quantity at this point
Hello civic owners. I just have to put this info out there. I am a GM All World and ASE Master tech (retired). My 01 Civic LX developed a drivability issue w/ CEL. Would not go over 30 mph no power intermittent. Code was TDC signal error/loss. Shut down wait re-start 50/50 run good until issue reset. Ok Cam sensor headed south. Did a a little research. Per Honda techs should replace both cam and crank sensor. Well understood. Sensors replaced now that’s then all the issues started!!!! Now upon start up PO336 set immediately goes into limp mode injectors killed at 3000rpm. ??? Ok got a bad crank sensor?? Replaced w/ 2nd new one (upgrade from first got a duralast autozone) . Exact same issue. Unable to test system after startup in limp mode yes RPM signal present. All other I mean ALL OTHER required tests completed pass. B+, 5v ref, grounds, continuity cam and crank circuits. Now In my mind I’ve created a wiring issue during repairs or just happens ECU went south w/ cam sensor??? From connectors, PGM relay to ECU to both sensors no problem found with wiring or reluctor rings. So what did I do to change cam code to crank code??? Replaced sensors. I replaced the Cam sensor a second just resurr myself no issue again with new sensor. Same exact issue PO336 immediately limp mode. Only other option..... I reinstalled the old crank sensor I took out. Guess what!!!!!!! Purring like a kitten!! Not really sure cause?? Guessing aftermarket sensors (2 different sources) just not fast enough to process signal on startup. Sensor I took out guessing OEM sensor. Yes has a dealership tech there is a quality difference in parts. I hope this just helps one person
Old Sep 10, 2019
Baelfyre's Avatar
A final update for others with a similar problem:
The misfire was apparently completely unrelated to the camshaft sensor issue; by pure bad luck a single fuel injector went bad at the same time as the sensor. Had it replaced, and the motor is purring like a kitten.
Thanks again for the swift and useful replies. It allowed me to rule out a number of things quickly.
rae_man
Sep 2, 2020 12:13 AM
themadness
26
Oct 23, 2012 05:21 PM
LividHatred
Jun 18, 2012 05:05 PM
xRiCeBoYx
Engine start problems
71
Apr 9, 2011 01:40 PM
CivicPro01
Sep 12, 2008 10:06 PM
