Cracked 02 LX Cylinder Head Cover
Old Dec 15, 2018
insoucient's Avatar
insoucient is an unknown quantity at this point
Just bought this 02 LX and put 200 miles on it. Popped hood to clean it up a bit and found this crack in the valve cover. Drives fine from 0-3000 RPM. No clue what causes this type of damage. To fix, I need to buy a new cover and gasket and install?
Crack on valve cover
Old Dec 16, 2018
Slumpertcivic's Avatar
Re: Cracked 02 LX Cylinder Head Cover
That’s a crack in the paint silly.
do not worry about it and any amount of picking at it will just make it bigger.
Old Dec 16, 2018
insoucient's Avatar
Interesting. I'll pull the cover off today and inspect it more thoroughly. I appreciate the feedback.
Old Dec 16, 2018
alishrouf's Avatar
alishrouf is an unknown quantity at this point
I think Slumpertcivic is right
but if you found it really leaking you can use a strong glow cheaper than buying cover with gasgate
Old Dec 16, 2018
Looks like corrosion with paint bubbling to me.
No oil leak so it's not a problem. Without removing the valve cover (necessitating gasket set replacement): Scrape, clean, repaint?
Old Dec 16, 2018
insoucient's Avatar
Fortunately, not leaking. Just very weird. Like what even causes that... I'm going to do a valve cover replacement, spark seals and gasket anyway.
Old Dec 16, 2018
A lot of money for something that's just a cosmetic issue. I'd shut the hood and forget about it.
Old Dec 18, 2018
mac25's Avatar
Dr Krieger of Modification
You could sand it down and use a touchup pen, or, silver nail polish, for a quick fix.
BasicCivicMan
Oct 14, 2018 02:08 AM
jcardenas14
Jul 22, 2012 01:30 AM
skarteez
Feb 14, 2004 01:52 AM
skarteez
Dec 31, 2003 04:11 PM
juscallmetoyota
18
Aug 12, 2003 01:12 PM
