Delay in plugs firing at start, normal?? (video)
Old Jan 3, 2014
soulraver's Avatar
soulraver is an unknown quantity at this point
Hey guys, i got this 01 civic ex from a friend and when i got it, the car would not start. I've only worked on 6th gen civics and earlier, so this car has a different ignition set-up. When i went to check for spark, i noticed all the plugs were drenched in fuel, and when i try to crank the car with one of the plugs out and grounded the plug does not fire for the first .5 - 1 sec every time. Even with new plugs, each cylinder has the same thing happen. Is this normal for this year of car? Check out the video below. BTW, when i press the gas in all the way, and start cranking the car studders a little like it wants to start but nothing.
In the video i am using an old plug, but the same results happen with my brand new plugs, gap checked and within spec.
Old Jan 3, 2014
soulraver's Avatar
Re: Delay in plugs firing at start, normal?? (video)
Its not letting me post a link to the video when it's all together:
h ttp://youtu.be/QJ7fBdxczIQ
Old Jan 3, 2014
soulraver's Avatar
Can no one help me out?? I just would like to know if this is normal for 7th gen civics, someone on this board must know.
Old Jan 3, 2014
I've never bothered to check what you are doing....but what I think is happening is the engine has to turn through at least 2 complete revolutions before sparks happen. It has to figure out where #1 cylinder is before it can pick out which coil to fire and when. (Other manufacturers do this, sounded good to me!)
Also, sounds flooded. Did someone move the car in the driveway and shut it off while still cold?
Cam timing off a tooth?
Cylinders need oiled?
Coolant temp sensor inaccurate?
Hold the gas pedal to the floor while cranking, this shuts off the injectors as a 'clear flood' mode. If it's simply flooded, it should eventually start trying to fire.
Old Jan 4, 2014
soulraver's Avatar
Thank you for the reply.. i thought it was a design thing but i have never heard of it.. ill have to check the timing and sensor, but at least now i can move past this spark issue.
Ninetyatecivic
May 9, 2015 07:48 PM
jetcare101
May 8, 2015 01:33 PM
Blaster30
Apr 22, 2015 12:21 PM
black2k1vtec
Dec 6, 2001 09:49 PM
