O2 sensor or A/F sensor
Old Oct 25, 2015
MichaelReid's Avatar
MichaelReid is an unknown quantity at this point
I've got an 05 civic and a while back i got an engine code P0135 heater circuit bank 1 sensor 1, so i thought no problem i know my way around cars and ordered an O2 sensor online (cause the one from the dealer was almost $400)
installed it no problem reset the engine light and a day later P0134 came up no activity bank 1 sensor 1. now after some research I'm finding on this year it's actually a A/F ratio sensor is this true before i drop a bunch of money to find out this info is wrong?
Old Oct 25, 2015
Wankenstein's Avatar
Re: O2 sensor or A/F sensor
Yes.. it's an A/F ratio sensor and it's model specific:
This is OEM for 2005 Civic EX:
Amazon.com: Denso 234-9017 Air Fuel Ratio Sensor: Automotive Amazon.com: Denso 234-9017 Air Fuel Ratio Sensor: Automotive
This is OEM for 2005 DX, LX, HX and VP:
Amazon.com: Denso 234-9005 Oxygen Sensor: Automotive Amazon.com: Denso 234-9005 Oxygen Sensor: Automotive
Old Oct 25, 2015
It's true, 04 and 05 use an AF sensor as the primary sensor (B1S1).
It's much more accurate than a regular O2 sensor.
Find your original sensor, locate the brand name on it (DENSO or NTK) and get the same brand replacement sensor.
Look up your car on the sensor manufacturers website so you have a good and correct part number to search for.
Stay the hell away from every other brand.
EDIT: I now see turd has posted the denso links, thanks
Old Oct 25, 2015
Three weeks ago I installed the 2nd linked Denso 234-9005 on my mom's 2004 Civic VP (codger mobile..67k original miles) and no CEL so far.
Old Oct 25, 2015
Originally Posted by turd_ferguson
OP.. 2001-2005 is 7th generation in case you didn't know.
Thread moved, thanx for the reminder
Uan
Aug 23, 2015 03:03 AM
horta1212
Aug 22, 2015 08:31 PM
Zugor
Aug 21, 2015 08:36 PM
PierrePierre
Aug 12, 2015 02:42 PM
Farticle69
Aug 6, 2015 08:02 PM
