? about replacing thermostat
Old Jan 8, 2014
kdliberty's Avatar
kdliberty is an unknown quantity at this point
Hindsight is 20/20. Let my Dad talk me into letting someone I didn't trust work on my car . (It is a 2002 Honda Civic EX.) He put a cheap thermostat on it that I am replacing with a Honda ASAP. (I am going to a Honda dealership to buy a new one Saturday.) Someone mentioned that there was a sensor I needed to go ahead and replace when I did the thermostat. What sensor do I need to replace? Also, does the coolant system have to be burped when they are done?
Old Jan 8, 2014
Re: ? about replacing thermostat
Head gasket.
Wait, what was the problem?
Pffft.
When was the head gasket job done?
Good for you!
Why?
Only the bad ones?
Yes
And if it never quits burping bubbles out.......it needs a head gasket job.
Old Jan 8, 2014
kdliberty's Avatar
it sticks open in very cold weather. silly I know. never seen one do that. once the engine is warm it is okay but takes forever. Just wanted to make only need to replace this cheap thermostat and don't want to take chances. I am not sure when the head gasket was done but it has been done. heater hoses, heater core and heater control valve are 1000 miles old. my mechanic checked the head gasket then. I have never had a problem with a car running to cold...
Old Jan 8, 2014
Make sure the jiggle pin is lined up right with the gasket, and is installed with the jiggle pin at the very top.
I lift the nose of the car up to bleed it faster in the shop, high enough to get the radiator higher than the hose outlet on the engine so the air can get out. (Might not be safe for you to do this though.)
Old Jan 11, 2014
if it is reealy cold, all my cars take 15 min highway drive to fully warmup
thana
Jun 15, 2020 07:05 PM
bo_red
May 4, 2015 01:47 PM
hokiedad4
May 3, 2015 10:06 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
