Oozing oil/headgasket
Old Apr 24, 2019
noquacks's Avatar
noquacks is an unknown quantity at this point
People,
2001 civic ex, original owner. 145,000 miles. Car starts every day, runs excellently. Has been oozing oil at right front corner of cyl head. Thing is, ifg it is a head gasket break why dont I see milkshake ooze under oil cap? Maybe it's not that bad yet?? I know it's gonna need one soon. Can I wait? It looses about a quart every 6 weeks (300 miles).
Thanks, people.
Old Apr 24, 2019
mikey1's Avatar
Re: Oozing oil/headgasket
head gasket wouldnt leak oil,
valve cover gasket, or cam seal
Old Apr 24, 2019
Colin42's Avatar
pics
Old Apr 24, 2019
noquacks's Avatar
Wow, I didnt know, mikey! Good to know! So, now I know I dont need a head gasket, which is such great news. Now, valve cover gasket is new, just had it done about a year ago. Wouldnt that include the cam seal?? I did hear about how our cars leak from the cam seal area. I will provide a picture asap and post here.
Only other thing I can mention is that the oozing is right where the trans bell housing meets up to the engine . Any ideas about that? .
Old Apr 24, 2019
noquacks's Avatar
After some thought, are you sure? Oil is pumped up to camshaft, and seeps back down. If a gasket is broken whats stopping the oil from seeping through the broken gasket to ooze out of the head while it's on its way down to oil pan again? I dont get it, mickey. Please explain a bit more, if possible.......
Old Apr 24, 2019
Post pics of your oil leakage please
Many other items are far more likely to leak oil, let us see what you are dealing with
Valve cover gasket, cam plug, vtec gaskets are common leak items (cam plug drools and runs down front of bellhousing/block area)
Head gasket would cause a different list of symptoms than oil leak
Old Apr 24, 2019
noquacks's Avatar
OK, ezone. thanks for the quick reply, and feedback. I am encouraged that it may not be the head gasket. It will take a day or 2 to get the pictures up.........
Old Apr 25, 2019
mikey1's Avatar
oh....when you said right side of the engine, i thought you meant the timing belt side,
you most likely need a new cam plug seal,
its a round plastic plug at the left end of the cam,
that would not have been replaced with the valve cover gasket
Old Apr 25, 2019
02civilx's Avatar
02civilx is an unknown quantity at this point
yea the plug seals the what used to be distributor mount. funny how they still make a distributor mount spot with the bolt holes on this engine when it uses coil on plug
Old Apr 25, 2019
noquacks's Avatar
Thanks again, mickey. Im hoping it is that plastic cam cover! How sloppy of them not to have popped a new one in when they had it all taken apart! I still plan on taking a photo, just to maker sure.......
Old Apr 25, 2019
noquacks's Avatar
But, once I determine that 100% it is that plug, I tried this before and those 12mm nuts on the EGR are MURDER to reach/get off with a regular socket! How does one do it? Maybe take a cheap box wrench and bend it to an angle? Other way?
Old Apr 25, 2019
mac25's Avatar
Dr Krieger of Modification
1/4 inch drive socket, elbow and three inch extension, worked for me.
Old Apr 25, 2019
noquacks's Avatar
Thanks, mac. This "elbow", is that a universal joint?
Old Apr 25, 2019
Probably.
The cam plug is Honda part # 12513-P72-003 and retail should be about 11 US dollars at any Honda dealership
(online may be cheaper but shipping may cost more than it's worth)
You may or may not need a fresh gasket for the egr valve, depends on when you pry the valve off if the gasket gets damaged or not
Old Apr 25, 2019
noquacks's Avatar
Probably.
Good to know, ezone. I was planning to use red rtv sealant if the egr gasket was old/damaged. Shouldnt that be good? Used it many times before for other engine parts.......
Old Apr 25, 2019
Red screams 'DIYer was here' LOL
Make sure any RTV you use clearly states that it is Oxygen Sensor Safe. Many are, but some are not so read carefully
Silicone in any form whether spray lubricant or RTV sealant or whatever, even the fumes from silicone sucked through the air filter of a running engine, will ruin oxygen sensors
Hondas 'Hondabond' rtv is gray color, Permatex ultra gray may be a suitable equivalent...
Some people smear a light coat of it around the new cam plug before installing it, even though the new cam plug from Honda has a new O ring on it already
Old Apr 26, 2019
noquacks's Avatar
I will remember that, ezone. I AM a DIY'r. But I appreciate tips from pros/other people, like the people here. So helpful. I have permatex black, actually. But let's see first whats under there........
Old Apr 26, 2019
Colin42's Avatar
just buy the gasket its $10
Old Apr 26, 2019
noquacks's Avatar
OK, ok, guess I will.......(sad face).
trying to get a picture up right now.......
Old Apr 26, 2019
noquacks's Avatar
heres the picture.
Old Apr 26, 2019
noquacks's Avatar
I shined a light right where the oil would be collecting/pooling IF it was leaking from the cam plug, but to my dissapointment there was no pooling of oil. Watched a few videos where some of our civics had same problem and they always showed oil pooling, as a result of the cam plug leak. So, does this mean the plug is good still, and it has to be the head gasket?
Old Apr 26, 2019
Your pic doesn't show the origin of the leak, just the evidence?
Take a pic pointing straight down---between the EGR valve and the head, including the round cam plug?
you could clean everything absolutely spotless then throw a bunch of talc/right guard/flour or any other light colored powder on the area, that would help lead you to a source once it leaks enough to leave a trail
Old Apr 26, 2019
noquacks's Avatar
Such a pic would be such a tough angle, ezone. I dont think its possible. Theres no way to get the angle one needs with the radiator housing in the way. But let me proceed to washing it all down, now that I took the pic with all the goo. Talc is a good idea. Have you even heard of the cam seal being at fault even if theres no puddle below it?
Old Apr 30, 2019
noquacks's Avatar
Update: What about the idea of removing the bulky air filter housing, and associated big black tube as well as the EGR valve, to provide access to view that part of the engine, then start the engine and run for just a bit, and while running view the leak as it actually seeps out? Can I do any serious damage to the engine? Can it run OK with EGR disconnected?
I dont think it needs to run more than say, 3-4 minutes, at the rate the oil is seeping out.
Am out of ideas, and this one is last chance to verify the seepage. I tried talc, but inconclusive- talc just gets soaked with oil, leaves no clear path of seepage source.
Old Apr 30, 2019
mikey1's Avatar
you can remove the big black intake box on top of the tranny and still run the car, your air filter will still be in place, all that box really does is make the intake quiet....its kind of like a muffler
Old Apr 30, 2019
noquacks's Avatar
Thanks, mikey! There is hope! Will try it tonight! But, I cant remove the EGR too, providing more space to view? Even if it creates a code, wont it revert back ok with no code showing after I install egr back again?
Old Apr 30, 2019
"Absolutely spotless" meant cleaning thoroughly leaving absolutely no traces of oil residue...before you throw talc at it.
It's possible to run the engine while EGR is removed, but it won't be pleasant. Most people should not attempt it IMO.
Old Apr 30, 2019
mac25's Avatar
With the EGR valve removed the exhaust gas that it regulates will vent to atmosphere.
It may also cause a miss fire.
You're looking to see if you have a leaking
-valve cover seal
-camshaft plug
-vtec solenoid seal (if applicable)
-rear main seal
Research the above items so you understand their function/location
Old Apr 30, 2019
there will also be a HUGE vacuum leak, and the engine will respond accordingly
Old Apr 30, 2019
If you're going to all this trouble just to hunt down the leak.....go buy the new cam plug and replace it just because you're already there
