loosing power for a seconds
Old Oct 28, 2018
alishrouf's Avatar
alishrouf is an unknown quantity at this point
Unhappy loosing power for a seconds
Hi all , hope i can found my solution here
i have 2001 exi honda civic , suddenly it start loosing power while idle or driving ( all gauges go down , stereo restart and the car coming to turn off for 2 seconds ) then it become ok again
the mechanics cleaned my bucket ( alternator changed , spark plugs changed , ground earth wires 3 changed ) but the problem is still there
note : this problem is happening 1 to 5 times a day
what to do ?? please help me thank u in advance
Old Oct 28, 2018
GolNat's Avatar
Prelude Owner
Re: loosing power for a seconds
Have the ignition switch checked.
Old Oct 28, 2018
alishrouf's Avatar
I thought its the ignition but when its losing the power my km trop A or B go back to the main km
mean : if im using trip A and the car lose power the screen swap to the main milage thats mean its totally losing power not only disconnect and connect again
Old Oct 29, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Another vote for a faulty ignition switch (electrical part).
Old Oct 29, 2018
alishrouf's Avatar
Thank u dear ,
My michanic chicked some relays behind the passenger bucket and he said one of them is too much hot , he changed it and he says its the ignition relay, the problem didnt come again , i wish its solved , ill come back again after some trys
Thank u all
Old Dec 8, 2018
alishrouf's Avatar
Thank you dear but the problem back again and sometimes the car turn off also
after i check i found the American style civic comes with sensor key but my car is only a steel key without sensor
any more help please .
Old Dec 8, 2018
user 8230230's Avatar
New Member
user 8230230 is an unknown quantity at this point
I don't know about losing power but I know about the "Sensor keys".
Do you have a green light the shape of a key on your dash when you turn the key on? The cars with the immobilizer do. It comes on when you turn the key on and then goes out once it has sensed the proper key. If the proper key is not sensed it starts flashing.
The system only prevents the engine from starting. It does not prevent it from running. Once running, you don't need the key so that would not be your problem.
Old Dec 8, 2018
Slumpertcivic's Avatar
If it made it for 6weeks without a issue, I would replace that same relay again. If problem again goes away again it’s a good starting point.
Old Dec 8, 2018
GolNat's Avatar
Prelude Owner
Are you sure? It looks like a regular key but there is a transponder inside it. The blinking key on the dash is what will tell you if you have one or not.
Old Dec 8, 2018
alishrouf's Avatar
First of all thanks for your reply
and yes dear im sure ( ME ) editions is totally different than the american edition ( no cruse control - no abs - no key light on the dashboard )
this is my key looks like store key LOL
Old Dec 9, 2018
alishrouf's Avatar
but sure there is a reason that make the relay weak or out of service !!!
Old Dec 9, 2018
alishrouf's Avatar
No sensor on my keys or the ignition switch in the ME edition
lxcivic98
Dec 17, 2014 05:51 PM
monstermunch
Mar 16, 2010 08:12 AM
blazed870
Jun 27, 2007 09:49 PM
SOHC
May 26, 2005 01:24 AM
thecheat
Aug 6, 2004 08:11 PM
