Changed O2 sensor, car jerks while accelerating
Old Feb 22, 2017
KraftDanner's Avatar
KraftDanner is an unknown quantity at this point
So a few weeks ago I had to emissions test my '04 Civic Si-G.
It was coming down to the wire so I quickly ordered a cheap O2 sensor online ~$60 and threw it in so I could clear the code I was having. Everything was fine but since then I've had a slight hesitation/jerking while accelerating at low RPMs.
Could this be from using the el cheapo O2 sensor and it not giving the correct air/fuel mix? I haven't tried anything else yet aside from new spark plugs.
I also have a P0497 code showing as well but from what I understand that shouldn't matter.
Old Feb 22, 2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Changed O2 sensor, car jerks while accelerating
I would use an OEM Denso O2 sensor and not cheap ones.
What was the original code?
Test the EVAP system for the other P0497 code. I had a P1497 code and it was solved by replacing the By-Pass Shut Valve and the Canister on the bottom of the car - this is a common occurrence with these cars FYI.
Old Feb 22, 2017
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
You sure you're talking about the correct sensor? A Denso O2 sensor does not even cost $60; I got mine for much less than that.
You sure you're not referring to the AIR/FUEL sensor, upstream of the cat?
Old Feb 22, 2017
That's what I got.
Old Feb 22, 2017
Original code was P0134, bank 1 sensor 1 no activity.
Thanks for the tip about the Denso sensors. I'm reading up on cheaping out and it's seeming more likely that I shouldn't have done that.
Sucks because the Denso is like $200 at least.
Old Feb 22, 2017
Cheapo price was TOO Cheap.
Correct is correct, price is no longer relevant other than being something to complain about. Denso #234-9017 is what I came up with for an 04 D17A2 engine. I'm seeing just under 100 USD on amazon for it.
Old Mar 13, 2019
2005ex's Avatar
Lstafford
2005ex is an unknown quantity at this point
I know this is an old thread and I've started a new one myself but did you end up buying the OEM air/fuel ratio sensor and did it fix your problem? Thank you
Curtman
Jan 11, 2019 03:32 PM
drhawkinz
35
Dec 28, 2014 12:37 PM
rbeatty
Dec 9, 2012 09:00 AM
civic99whistler
Aug 23, 2009 03:46 AM
cdmx
Dec 19, 2004 09:33 PM
