2005 Civic EX SE Window Issue
Old Sep 13, 2018
Jhunt96's Avatar
Jhunt96 is an unknown quantity at this point
Cool 2005 Civic EX SE Window Issue
I started having this issue about 3 months ago. My window would not work for some time (sometimes days and sometimes weeks), and then would randomly start working again. It has no rhythm or rhyme but I would try the window every day and it would randomly just start working agin when holding it down. It is only the driver side front window. All other windows work just fine. When the window does work, it has not issues. It rolls up and downs and the automatic down works fine, this is just rare that is actually does work. The latest time it was not working for about 3 weeks so I made an appointment to take it in for an electrical diagnostic and started working on the way to the shop this morning. I figured to not bring it in and see if anyone else has these issue. Please let me know if you can help. Thanks!
Old Sep 13, 2018
Slumpertcivic's Avatar
Re: 2005 Civic EX SE Window Issue
First thought is your window regulator motor has a flat spot, aka dead winding.
Bad wire harness and or control panel would likely show up even when it “works” by stopping working midway where as a bad motor winding once motor is spinning will keep spinning.
As long as it doesn’t stop exactly on the same dead spot will fire right back up again, but your dead spot is likely near at the full up position.
Its a cable chain system, but just maybe next time the window won’t go down, exit the car and with a hand on each side of the glass, try to push the window down just a little. Then try switch. If it suddenly starts going you know it’s bad motor.
Old Sep 13, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
The wires behind the rubber conduit at the driver's door hinge area may have broken. This is a common issue and has happened to me. The wires flex when door opens and closes especially the driver's door which gets lots of use. Repairing the wire(s) fixed the issue for me.
Old Sep 13, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
If you are ever in a pinch with your window stuck one way or the other, a good thing to try is to hold the window switch in the direction you needed to go and then open and slam the door while still holding the button. at 55 year old shop owning mechanic friend showed me that check and it's got me out of a jam a few times
Ek_Storm_B16
Oct 8, 2016 10:06 PM
Cmillett138
Jun 29, 2016 08:17 AM
TheHondaGuy
Aug 23, 2014 03:54 PM
R7derek
Jan 25, 2013 06:51 PM
nickrolando
19
Sep 2, 2012 06:46 PM
