'01 Civic EX engine oil leak
Old Feb 17, 2016
Dooner's Avatar
GOT SAND?
Dooner is an unknown quantity at this point
So I recently purchased an '01 Civic EX, and it's developed an oil leak. It appears to be coming from the top of the motor, and running down where the trans mates to engine. It's not coming from the valve cover. I can't quite detect where the source is, although it's in the area of the EGR valve. Is this a common problem on these cars? Anyone have any thoughts? Is there a quick & easy fix or DIY for whatever this may be? Any help is greatly appreciated.
Old Feb 17, 2016
mikey1's Avatar
Re: '01 Civic EX engine oil leak
there is a round black plastic plug at the end of the valve cover, replace that
Old Feb 17, 2016
Hondas part number 12513-P72-003
Should be about $9 at a decent dealer.
If the engine has an EGR valve you might need to remove it to get the plug out.
Some pics in these threads
https://www.civicforums.com/forums/3...-oil-leak.html
https://www.civicforums.com/forums/1...ak-up-top.html
Old Feb 17, 2016
Dooner's Avatar
GOT SAND?
Thanks fellas! I just came back from getting the cam plug cover & EGR Valve gasket at my local stealership. I'll have to wait until my next day off to make the fix.
Old Feb 29, 2016
user 84948's Avatar
New Member
user 84948 is an unknown quantity at this point
Always appreciate your tips ezone (you helped me extensively with an electrical diagnosis last year). I noticed my cylinder head plug was also leaking. Just picked up the part for $9 at the dealer and will install later this week. I would replace it today, but can't get EGR bolts off without a universal socket adapter (which I don't have yet). Is the Hondabond or RTV black stuff required (does it hurt/help)? Parts guy said just put some oil on the O-ring.
Old Feb 29, 2016
mikey1's Avatar
that should be all that is nessessary/required,
although i dont think a very small dab of high temp silicone would do any harm
Old Feb 29, 2016
^Ditto this^......but I don't normally use extra sealer myself.
Old Feb 29, 2016
Dooner's Avatar
GOT SAND?
Finally did the minor repair, and I just oiled the O-ring on the cam plug, and installed it. Presto! Instant stop leak! If it fail in the near future, so be it. For $8 and about 10 min of your own labor, it's easy enough to do.
kevfarr
Sep 18, 2015 02:28 PM
beantech
Sep 6, 2015 01:46 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
colombianDXcivic
Nov 8, 2001 05:26 PM
