Check Engine Light P1259
Old Jul 23, 2022
Carnage65's Avatar
Carnage65 is an unknown quantity at this point
Hey everyone I have a 02 Civic Ex 1.7lt Vtec the issue I'm having is this error code I can't get it to go away.. I've replaced the whole thing and still won't engage VTec.. Any suggestions??
Vtec Part
Old Jul 23, 2022
Re: Check Engine Light P1259
oil pressure activated (aside from electrical/electronic)
  • do you have enough oil in the engine?
    • potentially oil passages obstructed?
  • might be damaged wires to the ECU
  • you are getting the VTEC code, so assume ECU is for the VTEC engine, and your car is an EX. But if above three items are OK, could be ECU problems? (changing ECU is challenging, anti-theft keys need to be programmed to it)
khonschevy
Feb 18, 2016 05:01 PM
skaterboy2214
Mar 11, 2014 05:37 PM
jcd3t
17
Mar 18, 2011 11:00 PM
ksteak
Oct 15, 2008 03:03 PM
WilmncChris
Feb 8, 2006 05:48 PM
