Engine Surges When Pressing Brakes
Old Aug 16, 2021
Shrieking Geek's Avatar
Shrieking Geek is an unknown quantity at this point
Good Evening Everyone,
I have suspected a vacuum leak in my engine for a bit now. Today I rebuilt the entire intake assembly with brand new gaskets. But I think I have a vacuum leak because with the car in park and idling, if I press on the brake pedal, the engine surges to a higher RPM and doesn't go back down to idle. Does anyone have a solution for this? Or can guide me to what may be wrong?
Thanks
Old Aug 16, 2021
Takato's Avatar
Takato is an unknown quantity at this point
Re: Engine Surges When Pressing Brakes
Does the idle return to normal when you let off the brake? Or when you drive for a little bit and brake normally? To me the increasing of rpm's sounds normal. When you're idling and you press the brake pedal you are using the vacuum pressure stored in your brake booster so the engine needs to restore this pressure. It does this by increasing the rpm to produce more vacuum to satiate the need of the brake booster
Old Aug 16, 2021
Colin42's Avatar
Check the brake booster
Old Aug 16, 2021
It does not return to idle. And it is a large jump in RPMs. Like up to 3K I'd say. I also tested my brake booster and that and the check valve are in good working order.
nieuport17
Nov 21, 2012 12:30 PM
SlimRisk
Nov 1, 2011 10:55 PM
odysseus
Feb 25, 2010 01:42 PM
cycleboy506
Wheels and Tires
Jan 22, 2010 11:49 PM
JerryKay
Jun 5, 2009 03:41 PM
