Any harm in doing a valve clearance adjustment?
Old Jan 3, 2022
7thgenlegend's Avatar
7thgenlegend is an unknown quantity at this point
Civic has 214k miles. I was too tired to check / adjust valve clearances when I did my timing belt last month. I'm worried of a potential that the valve clearances might be too tight and burn a valve. At this mileage, is there any risk of doing valve clearance adjustment? It's probably never been done since leaving the factory. If I do it, I plan on adjusting tight valves just within spec on the tight-end, and loose valves just within spec of the loose-end.
I've done valve adjustment with bucket-over-shim sport bikes but I'm still not sure if there's any risk in doing it at this high of a mileage.
Old Jan 3, 2022
treborabc's Avatar
treborabc is an unknown quantity at this point
Re: Any harm in doing a valve clearance adjustment?
I wouldn't think so. I did mine at 192k miles, don't even think I did that good of a job at it at that, and didn't notice any problems from it. As long as you keep it within tolerances it should be fine. I went back through the set of valves to check the tolerances before closing up.
Old Jan 3, 2022
If anything, it'll help. Definitely keep it within tolerances, and make sure you're doing it with the head cold (<100F)
D17A1 (dx/lx - 1.7L SOHC non-VTEC) adjuster nut torque is 13 ft-lbs (156 in-lb)
D17A2 (ex - 1.7L SOHC VTEC) adjuster nut torque is 14 ft-lbs (168 in-lb)
Intake clearance spec is .007"-.009" (.18-.22mm)
Exhaust clearance spec is .009"-.011" (.23-.27mm)
Every time I did mine on my 2002 civic, I used .008 and .010 feeler gauges for intake and exhaust, respectively.
Old Jan 4, 2022
Red face Re: Any harm in doing a valve clearance adjustment?
Sounds good i'll give it a crack in one of the upcoming weekends.
Thanks for the feedback
Old Jan 1, 2026
Treedguy's Avatar
Treedguy is an unknown quantity at this point
I have a 2002 SI.
Are the clearance specs the same?
Old Jan 1, 2026
FRSam's Avatar
Click Here
Originally Posted by Treedguy
I have a 2002 SI.
No. Two vastly different engines.
Intake specs appear to be the same at 0.007-0.009, but the exhaust are set at 0.011-0.013.
gregplc40
Aug 3, 2021 11:54 AM
Razgriz1500
Sep 15, 2012 11:29 PM
thewal
Jul 30, 2009 12:10 PM
Eyger
Wheels and Tires
Feb 20, 2008 09:34 AM
draganjr
Texas
Sep 28, 2007 05:48 PM
