04 Lx Acceleration Issue
Old Feb 25, 2023
Esax's Avatar
Esax is an unknown quantity at this point
Hey y'all, recently we bought a 2004 civic lx 1.7L, and along with many other issues the biggest is that the car will not accelerate properly. Its very sluggish and will not go above 50~ mph. We have replaced the air filter and after clearing the Catalytic Converter only the reverse seemed to accelerate better, strangely the maint. req. light is not on, though the key light, oil light (oil is fine), and check engine lights are on, which we think might point to a computer issue. Car also takes a bit to start up, but we don't think that is related. Any input or ideas? Thank you.
Old Feb 25, 2023
Re: 04 Lx Acceleration Issue
maintenance required is just a mileage based to call for oil changes and such
read the CEL codes first and foremost
Old Feb 26, 2023
Colin42's Avatar
The check engine light is on for a reason. Find out what the codes are.
Old Feb 28, 2023
Esax's Avatar
Thats the issue, and thats my fault cause I forgot to mention it, the codes won't read. We've tried 3 different code readers and every single one of them fails to connect/cannot find a connection, so it won't even register that its connected to the vechical.
Old Mar 1, 2023
BrotatoChip's Avatar
Super Moderator
Has work been done to the engine recently? Check alternator mounting bolts. There are three not including the wing nut.
Old Mar 1, 2023
Colin42's Avatar
Check the fuse as well
fa900
Aug 30, 2021 12:14 AM
djkamar
Apr 14, 2016 09:33 AM
cburris
Apr 21, 2014 05:27 PM
rlbtkd1
Aug 19, 2012 08:55 AM
rt207
May 30, 2006 05:44 PM
