2001 Honda Civic lx stock pinging???
Old Jun 1, 2022
2001hondacivc's Avatar
2001hondacivc is an unknown quantity at this point
So my 2001 Honda Civic pings in in the higher rpm’s . So I started running 91 octane in it about a year and a half ago. That totals stops it from pinging. But why would a stock 2001 Honda Civic be doing this? Only reason I think it’s pinging noise because it goes away when I run high octane.but comes back once I drain the tank a refill with 87. Since gas prices have gone up I’d like to go back regular gas.
Old Jun 1, 2022
Re: 2001 Honda Civic lx stock pinging???
carbon deposits is one potential cause.
moved thread to mechanical issues section
Old Jun 1, 2022
Colin42's Avatar
Yeah have a look in the combustion chambers, you can get inspection cameras pretty cheap now. No check engine light?
Old Jun 1, 2022
Only check engine light I get is p1457 . I think that’s the code number I can’t remember . It says it’s a Honda specific code . I think it has somthing to do evap vent Solenoid. I only get that code once it getsto almost 3/4 of a tank that code pops on. If I reset the code and keep the tank full it takes about 300 to 400 miles before it comes back on. I’ve done a lot of experimenting. Thank you for confirming I was thinking maybe it could be carbon deposits on top of the pistons cause it to ping. Sorry for posting in the wrong section.
Old Jun 1, 2022
Colin42's Avatar
Yeah evap related, wouldn't affect the pinging, are you in the rust belt?
does it burn oil?
darline1940
Apr 12, 2012 09:02 AM
