Headers glowing red after idling for 10+ min
Old May 2, 2022
Civic2727Spikes's Avatar
Civic2727Spikes is an unknown quantity at this point
I am having an issue, it only happens when I idle for an extended period without moving.. Say over 10-15 minutes. My exhaust headers will be glowing red hot and I have a lack of power. Once I turn the car off for a little bit, or if i can get the car moving fast enough to get some air rushing through the problem goes away. It's not a huge issue as I know how to avoid it but I am wondering, does this mean I have a clogged cat????? I have the Civic LX with the d17a2 I believe, the non vtec sohc variant motor - manual transmission.
Any ideas of a possible cause or solution?
Thank you kindly ~
Old May 2, 2022
Colin42's Avatar
Re: Headers glowing red after idling for 10+ min
Cat is probably clogged, loosen the exhaust before the cat and see if that makes an improvement
Old May 5, 2022
hmmm thats what I was kind of thinking too. I will see if i can take it off and clean it,
Scotty says you can put it in some laundry soap and let it soak for a day ad it will clean it all up.
Or i could just say F the cat and shove a long metal pole in there and beat the **** out of the catalyst and break the inside up so itll never clog again , lol and be better flowing
Old May 5, 2022
just check your local laws
Old May 5, 2022
Colin42's Avatar
Scrap the cat, the money you get will pay for the cost of a new aftermarket one
Shrieking Geek
Aug 15, 2021 07:36 PM
Civicracer2002
Mar 16, 2006 08:09 PM
Tomola
May 2, 2005 04:53 AM
MOUSE
Sep 12, 2002 04:19 PM
MOUSE
May 23, 2002 05:42 PM
