Please help
Old Jul 8, 2023
Inkedup9's Avatar
Inkedup9 is an unknown quantity at this point
Please help
Ok so i got a d17a1 head on a d17a2 block I. Trying to figure out why it won't start it's almost acks like it wants to but then it doesn't anymore need help badly please
Old Jul 8, 2023
Re: Please help
first things first.. Did the car originally come with a D17A1 or A2? And are you using a D17A1 or A2 ECU?
Old Jul 8, 2023
Inkedup9's Avatar
Re: Please help
It came with a d17a1 in it and ive hand gone through a few blocks other bs reasons but now I got a d17a2 block but my a1 head on it
Old Jul 8, 2023
Inkedup9's Avatar
Re: Please help
A1 ecu same as head
Old Jul 9, 2023
Re: Please help
well, there goes my initial train of thought.
Does it crank forever and not turn over? If so, is the green key light perpetually illuminated on the custer?
Old Jul 9, 2023
Inkedup9's Avatar
Re: Please help
Lol if I could see it but I got a new cluster cuz my old one broke and for some reason it's not working I have pin digrams that I have to look at for those
Old Jul 9, 2023
Inkedup9's Avatar
Re: Please help
But yeah it's just spinin no crank iver been trying to find the right crankshaft and camshaft wire pinouts for this year and I cant find them think that was a issue
Old Jul 9, 2023
Re: Please help
if cluster not working, check engine codes
Old Jul 9, 2023
Inkedup9's Avatar
Re: Please help
No check engine codes
Old Jul 9, 2023
Colin42's Avatar
Re: Please help
Timing correct?
Old Jul 9, 2023
Inkedup9's Avatar
Re: Please help
Re checking everything now
Old Jul 9, 2023
Inkedup9's Avatar
Re: Please help
Ok checked out everything and it goes and acks like it wants to start and then won't and then my plugs are flooded in gas
Old Jul 9, 2023
Inkedup9's Avatar
Re: Please help
Ok yes it's trying to crank and almost does the first time but then after that it's flooded out
Old Jul 9, 2023
Colin42's Avatar
Re: Please help
Pull the plugs, disable the injectors or pump, and then crank it a bunch to clear the cylinders. Check if you have spark. If you do leave the plugs out overnight, and then throw a tablespoon of oil in each cylinder, reinstall the plugs and try to start
Old Jul 9, 2023
Inkedup9's Avatar
Re: Please help
Ok will try tmro we just got hit with a bunch of rain
Old Jul 10, 2023
Inkedup9's Avatar
Re: Please help
Okay so I did everything like the last person said and it goes to act like it wants to start and then it that's it and then after that it'll act like it'll start one more time and then you smell nothing but gas
Old Jul 10, 2023
Re: Please help
I've kinda been stuck on "immobilizer issue" and I still kinda am. The make or break is going to be how the immobilizer acts, since I cant remember if it just cuts spark or if it cuts spark and fuel. All I know for sure, if you have an immobilizer issue, it will crank forever and never turn over
Old Jul 10, 2023
Inkedup9's Avatar
Re: Please help
immobilizer? What is that ? It's just flooding out after first start
Old Jul 10, 2023
Re: Please help
immobilizer disables the fuel pump, so if it is flooding, I would check it off.
so timing correct then? Sparking?
possible sensor issue?
use starter fluid?
Old Jul 10, 2023
Inkedup9's Avatar
Re: Please help
I don't know if this is allowed but here goes my phone number be awesome if you could give me a call dealing with a POS phone so it takes me forever to get anything in but if you can give me a call at the awesome very much appreciated trying to figure this situation out now since my car's been down for about 2 weeks now and can't get to work
Last edited by sdaidoji; Jul 10, 2023 at 06:26 PM. Reason: removed phone number as per forum rules
Old Jul 10, 2023
Re: Please help
sorry, you better not have your number floating in the net.
You can:
Old Jul 10, 2023
Re: Please help
use starter fluid?
****, I thought it cut spark at the least. I was way off there. You have, at least, a spark issue. If you've cranked it a lot with no engine firing, you may want to pull your plugs and let the entire thing "air out" for a day. If you're smelling gas/plugs are wet, I'd venture a guess that fuel delivery isn't the problem.
Test the spark plugs and coil packs, as well, just to make sure you got spark there. It'll take a second person, but pull the coil pack and the plug, put the plug into the business end of the coil pack, plug in the coil pack, hold the tip close to something metal (exhaust manifold is what I've used in the past), and have someone crank the engine a bit. If you see an arc from the spark plug to the metal thing, coil pack and spark plug tests good. If so, move onto the next plug/coil combo. If you don't see a spark, try another plug (if you already tested one good, swap that one in) and test again. If still no spark, try another coil pack (again, if you tested one good, use that one). If either new combo works, whatever you swapped out is likely one of the points of failure. If you get good results on all 4 plugs and coils, then you're back at square 1. Any and all "failed" components prolly need to be replaced
Greg DePrima
May 26, 2017 03:50 PM
FerstlerSlim
Engine Swaps
15
Oct 22, 2012 10:06 AM
EM2_JDM_AS_FUHH
Apr 7, 2011 04:19 PM
Z3k3dafreak757
Feb 6, 2011 07:05 PM
ST8RACE
Engine Swaps
Jan 30, 2007 10:33 AM
