Drive Belt(s) diagram
Old Sep 15, 2024
Goodboykane's Avatar
Goodboykane is an unknown quantity at this point
I own a 2005 civic EX 1.7 special edition. I need to replace the drive/serpentine belt soon and I can’t find a diagram anywhere. Does anyone have a diagram they can share? Thanks!
Old Sep 16, 2024
Colin42's Avatar
Re: Drive Belt(s) diagram
It's very straightforward if you look in the engine bay. Make your own diagram if you need to.
Old Sep 16, 2024
which belt in particular. the D17 is a bit different than a normal serpentine belt since it uses 3 different belts. It's been a minute since I've tinkered with a D17, but IIRC, you have the PS pump off one belt, Alternator and AC compressor off another belt, and the timing belt that drives basically everything else (I'm gonna assume you're talking timing belt). Like Colin said, it's pretty straightforward. However, if you need a diagram, here go. The other belts are single or dual pulley, which all contact the inner surface of their respective belts.
IfollowUdie
Nov 25, 2021 11:52 PM
dave_type_s
Mar 30, 2018 04:49 PM
DBASRA99
May 27, 2014 07:58 PM
yellowjacket
Oct 24, 2004 10:06 AM
