Valve spring compressor D17A2 VTec
Old Aug 8, 2023
Jesshaines's Avatar
Jesshaines is an unknown quantity at this point
Can anyone recommend a good in car valve spring compressor tool? It's a 2002 Civic EX VTEC.
The crappy one from harbor freight isn't fitting on the valve spring. Go figure. I might hitch a ride to AutoZone and try there $20 version.
I'm hoping someone here has some beta on one that will work for sure.
Finding plenty of tools that thread into the rocker arm assembly holes for B series but so far nothing for d series. Searching on the form turned up nothing too.
Thanks in advance!
Old Aug 8, 2023
Re: Valve spring compressor D17A2 VTec
not sure the brand I used, but it took me a good amount of searching and calling to find it locally. It looked similar (if not nearly identical) to this one I found on Amazon. I still had to get creative when taking off the intake valves because of the spark plug tubes.
Amazon Amazon
Old Aug 8, 2023
Jesshaines's Avatar
https://www.amazon.com/JEGS-W89409-V.../dp/B007VR7V1G
Thanks for the reply. Unfortunately that style won't work for me since I'm not removing my head.
I'd like to find one like this but for d series
https://www.ebay.com/itm/31473778314...emis&media=SMS
Old Aug 8, 2023
good luck on finding one for D17 that does not require removing the head
there might be some special honda tool, maybe
Old Aug 8, 2023
oh yeah, those overhead ones you can pick up at autozone won't work on the d17. You'll need to remove the head to remove the valves
rogersracing89
Air Conditioning
Jul 8, 2020 12:12 PM
TRIZ
20
Jul 26, 2007 05:03 PM
civictuner
Oct 29, 2004 07:46 AM
R1Style
Jun 10, 2003 11:23 AM
nitrous696
Jun 24, 2002 01:54 PM
